Mk 3 rear brake master cylinder
Has anyone replaced the standard mc with a neater smaller one.??
I have rearsets on my bike and the current set up is an abomination. I'm looking for a smaller unit but not sure how it would effect the operation if the slave cylinder , so any recommendations would be appreciated. Cheers.
Hi Hans
I use a 13mm rear brake master cylinder from a Yamaha YZF125  works well and cheap as chips on ebay.
Best regards
Katherine Scott
Evening Hans
I used a 13mm Grimeca master cylinder, bought from an autojumble for a fiver, what ever you do take into account the smaller cylinder and the lever ratio used, try and get the ratio to match the cylinder so your not over braking the rear wheel.   left side rearset
