I'm having my wheels rebuilt and the man doing it has asked if there is any rim/hub offset on the Norton.
A number of other makes for which he does this work do have offsets.
I can't find anything in the literature nor the web.
Can anybody help?
Hello Richard _ No offsets…
It depends what you mean by…
It depends what you mean by offsets, Howard is right in that the rims are centred on the hubs so there is no offset in that sense, however if you are measuring the edge of the rim from say the edge of the brake drum then there may be. The RGM website has a pdf with those measurements if your builder needs them.
https://www.rgmnorton.co.uk/csi/1245184/f/pdf/wheel_offsets.pdf
Dan
Wheel offsets
Thank you for these, it confirms what I suspected, there is no offset wheel rim to hub.
Richard
Hello Richard _ No offsets on a featherbed Dommie thank goodness. Cheers. Howard
