Hi has anyone out there converted a Jubilee from 6 to 12volts I have decided this is the way to go so any help would be welcome (but keep it simple!) electricity and smoke are not my strong point, apologies if its going over old ground.
Cheers Dave.
On this web site go to Tec…
Hi Colin, Thanks for the i…
Hi Colin,
Thanks for the info,that will be a great help.I am new to the club so some of the web site is still a mystery to me.
Cheers Dave.
Well that's sorted then!…
Well that's sorted then! 6V to 12V and fit a Boyer ignition at the same time allows you to use the original 6 v coils. You get easier starting, less vibration, longer engine life, better lights, greater choice of lamps and batteries and still ride a Norton!
Al Oz
Just got my prewar 16H on…
Just got my prewar 16H on the road - 6v generator and CVC to look after charging - seems OK at present. But Al's point about bulb choice stikes a chord. 6 volt twin filament bayonet fitting headlamp bulbs seem to be in rather short supply. Searched for ages and found one at Kempton the other day. Will 6 volts die out very soon - when we can no longer buy bulbs? Or is there a huge secret stash somewhere?
Vehicle Wiring Products ha…
Vehicle Wiring Products has a great choice of 6 and 12 volt bulbs.
Previously David Cooper wr…
Now you know how it is for those of us who live in the USA. Buying a 12v headlight bulb for Brit bikes is not easy, it usually requires going to someone who specialises in British bikes. Not like back home where they were available from any petrol station...
On this web site go to Technical->Electrical->6v to 12v Conversion and that will take you to a nice piece on the subject by Al Oz.
