Dynamo speed?
I've rebuilt the Norton dynamo, but the brushes seemed fine so I reused them. The commutator was oily but has cleaned up nicely. When reassembled, I'm getting good continuity between the D terminal and the dynamo body - 4 ohms or so, and can see it fluctuating as I rotate the spindle. Again continuity between the F terminal and body of around 5 ohms (there are based on my memory so are approximate and may even be the wrong way round).
The dynamo motors well and in the correct direction with a small 6 volt battery.
However, when I join the F and D terminals and spin the dynamo with an electric drill, I see only a tiny voltage between the F and D and earth. Is it merely that I'm not spinning it fast enough to start generating?
I seem to remember I had a similar problem years ago with an A10 dynamo and took it to Tony Cooper who returned it to me working and charged a very small amount but I don't know what he did to it (if anything!)
I have been working on my E3HM generator. I've checked the field coil, the armature and all tested good, I cleaned and checked the brushes as well.yet it produces only 4vlts at about 2000rpm.It does motor when D&F are connected.
I re polarized it and no difference.
I ended up ordering a new armature & field coil .
I had a similar problem. It turned out to be poor earthing between the dynamo body and the bike. Some things you shouldn't paint...
Mine isn't actually fitted to the bike at the moment....
I think I'll just put it away till the bike's running (shouldn't be too long now) then try it in situ. I was only looking at the dynamo as I was stalled waiting for some other parts.
Hi Ian,The dynamo needs to be turning at about 1000rpm for it to excite its self then the faster it turns the higher the voiltage.If it is still not working at 1000rpm you ether got it wired wrong or the armature has a problem and it will need to be tested on a growler and the field coil should have a resistance between 2.8 & 3.2 ohms.If you live near Bristol i will test your armature on a growler for free.Beat of luck Paul Wolf 07831446958
Many thanks for the offer Paul - a bit far for me as I'm in Brum but I will bear it in mind!. I suspect that I wasn't getting it turning fast enough as the no load speed of the drill is only about 1200 rpm.
I've popped it on a shelf while I get on with other jobs. I had the bike running for the first time the other day and apart from a bit of clatter at the top end (probably starved of oil) and wildly misadjusted carb it was sounding good.....
