Most Brit bikes had + ve earth dynamo systems. Which is better?
Does it take much to switch polarity? Is it more than reversing the battery and re-flashing the dynamo?
Hi Paul, My pre 1953.singl…
I like negative earth as i…
I like negative earth as it's the same as other vehicles in the family and my ageing brain is very easily confused.
Paul has raised a very imp…
Paul has raised a very important point with his posting. When I bought my 1948 ES2 I had no idea whether it was positive or negative earth. I rashly assumed it was positive like all of my Dominator bikes.
The wiring diagram in the manual did not really help as it shows the battery wire colours but not the polarity of the terminals they connect to. See attachment.
Somebody call Al Oz and ask for some guidance on this very important matter.
es2-wiring-diagram-doc
Interestingly, my older bi…
Interestingly, my older bikes (Velo, Rudge) are negative earth but my newer ones (Norton, BSA) are positive earth. The very first Land Rovers were positive earth but thereafter all were negative earth. The universal standard now is negative earth for vehicles. It would seem that there is an argument in favour of negative earth for marginally reduced corrosion but frankly I don't see any discernable difference.
What is scarily amusing is when jump leads are used between a positive earth vehicle and a negative earth vehicle and the two are touching bumper to bumper (has to be metal bumpers of course).
Flashing the dynamo and swapping battery leads is pretty much it - unless you have a solid state voltage regulator which would have to be changed.
Al Oz here. All the above…
Al Oz here. All the above is correct so far. But please look at the pdf on my web site via the big Orange Icon RHS. Your last words are correct Gordon BUT you forget the colour of the wiring especially earth wire. Yes by re-polarising the Dynamo and turning the battery around it all works. Next time you reconnect the battery the wrong way round you could find your electronic regulator turns into a puff of smoke. The mechanical regulator will change polarity and it has even been know for a bike (Mech reg) and battery to change its polarity, and nobody knew........
The thought that you have 6 vehicles neg earth and you don't want a 'rouge' in them so ALL are neg earth is a very good point. But do be aware of the next owner of the vehicle he might expect Pos. and you have it neg. so the CORRECT wire colours will help.!
The diagram mentioned above is very bad, as you say no polarity.....
The change to pos. earth came through in the 50s but was subsequently found to corrode copper radiators...but on a motorcycle? Certainly there is a case to reduce (pos.earth) corrosion. I have half a theory on this polarity change, but not to put it into words or some bozo will start to believe it...In the mean time is there any one about who was in the motor industry in the 50s who might know the reason for the change?
Al - I am assured by my el…
Al - I am assured by my elderly motorcycling/motoring friend (92+yrs) that we went positive earth in the early '50s in the UK to satisfy the American market which expectedit or demanded it for the export market. A bit like wrong side gear changes...it's all their fault.
He also suggested that he thought that positive earth was supposed to be worse for battery terminals - which would of course apply to motorcycles.
Presumably the US motor industry eventually woke up and changed their ideas.
The US was a major export…
The US was a major export market for Vincents, and all were - ve earth. But they did get compulsory sealed beam headlamps.
My wiring loom is not a factory one and has brown wires on the loom for the feed wires, and black for earth. It has two male bullet connectors on the feed side, so I put a female bullet on the earth wire. That way I can't put the battery in the wrong way round.
I'm thinking of fitting an electronic regulator, and need to decide if I'm going to switch to - ve earth. So far I haven't seen a reason why not to do so, it looks easy - just turn the Cyclon batteries round and flash the dynamo the other way
Previously ian_richtsteig…
Previously ian_richtsteig wrote:
Hi Paul, My pre 1953 singles and twin are all negative earth and my Commando and featherbed Dommi and Es2 are all positive earth. I don't see any differences in plug life or points wear with either system.
regards Ian
Here's the wiring diagrams showing pre 1953 negative earth and post 1953 positive earth. This may help members.
Norton%201953-1955%20wiring%20.pdf
Norton%201956%2057%2058%20%20wiring.pdf
ww
Thanks for posting the dia…
Thanks for posting the diagrams. I couldn't get my head around the ones which are upside down, but reading the other, it's apparent that they diagrams are the same whether + ve or - ve earth. I just had a look in my Model 88 / 99 factory manual (the black covered one), and the diagram does not show whether the bike is wired + ve or - ve earth! It just shows two terminals, and I used pencil to put the + and - on it! So it's a choice.
Hi Paul, My pre 1953.singles and twin are all negative earth and my Commando and featherbed Dommi and Es2 are all positive earth. I don't see any differences in plug life or points wear with either system.
regards Ian
