Jubilee gearbox cover kickstart side wanted.
I have the later gearbox and I am missing this cover would be grate if someone had one spare.
I have a spare bottom end engine spare if anyone needs one Cheers
phill
I've got barrels and pist…
I am pretty certain that I…
I am pretty certain that I have a gear box cover for the later engine which I bought accidentally as all my engines are early ones. I will search it out later today-it should be in the spares box and I think it looked OK to me.
Patrick
Here's a picture of the g…
Here's a picture of the gear box cover. I have never had a bike with the later gearbox so I don't profess to be an expert on these items. It looks OK with good joint faces. It's got what the pundits call 'patina' and the level screw appears to be stuck. A good polishing up though would probably sort it.
Maybe Dan has a better one.
Patrick
p9040094-2-jpg
The inside picture Attachm…
The inside picture
p9040095-jpg
I've found mine but they…
I've found mine but they are both early type, sorry!
Dan
Previously patrick_mullen…
The inside picture
Hi Patrick
sorry for the late reply. Thanks for looking. And that's the one I need how much for it ?
Thanks phill
Previously Dan Field wrote…
Dan
Thanks for looking ð
message sent
message sent
I've got barrels and pistons for the top also!
ill have a look and see what cases I have tomorrow, I think mine are ealier ones but you never know!
Dan
