Hi all,
can anyone send in a photo of the Jubilee battery strap, with dimensions, or any info to help me build, or where to purchase this item? Norton part number is 21032 in the spares book.
All the best,
Skip Brolund
Hi Skip, Is your Jubilee a…
I used a big o ring, works…
I used a big o ring, works a treat!
De Luxe battery box and st…
De Luxe battery box and strap.
pb270094-jpg
And another picture of fix…
And another picture of fixing
pb270095-jpg
Thank you all !!!!!
Thank you all !!!!!
Hi Skip,
Is your Jubilee a De Luxe ? The Standard Jubilee uses a rubber strap which you can make in minutes from an old inner tube. I can probably get you a picture tomorrow of the De Luxe one but it is a simple metal strap which is bolted on - it only has to keep the battery from falling out.
It's frosty and cold here and I'm too comfortable here by the fire to go out to the garage.
Patrick
