hello there may be BA 2 if…
Hello Fritz, The dial scre…
Hello Fritz,
The dial screws are 2.00mm dia. X 0.45 pitch x 5mm long.
Paul.
Thanks Paul. As we should…
Thanks Paul. As we should all know, Chronometrics, like their Jaeger predecessors, are entirely metric. Too many people fix them to their brackets with 1/4" BSF or 2 BA nuts instead of the correct 6mm ones. You can horrify the rivet counters by attaching your instruments with freely available stainless nyloc 6mm nuts. Stops them falling off...
Previously Gordon Johnston…
Previously Gordon Johnston wrote:
â?Chronometrics, like their Jaeger predecessors, are entirely metricâ?
Interesting, good to know. Thank you George.
Fritz
Previously Paul Knapp wrot…
Previously Paul Knapp wrote:
Hello Fritz,
Paul.
Regarding the comment from George, so those are M2.
Thank you Paul.
Fritz
hello there may be BA 2 if this helps yours Anna J
