Screw size on a chronomatric
Somebody knows the size of the four screws on the chronometric dial?
Fritz
speedo-jpg
Thanks Paul. As we should all know, Chronometrics, like their Jaeger predecessors, are entirely metric. Too many people fix them to their brackets with 1/4" BSF or 2 BA nuts instead of the correct 6mm ones. You can horrify the rivet counters by attaching your instruments with freely available stainless nyloc 6mm nuts. Stops them falling off...
Previously Gordon Johnston wrote:
â?Chronometrics, like their Jaeger predecessors, are entirely metricâ?
Interesting, good to know. Thank you George.
Fritz
Previously Paul Knapp wrote:
Hello Fritz,
The dial screws are 2.00mm dia. X 0.45 pitch x 5mm long.
Paul.
Regarding the comment from George, so those are M2.
Thank you Paul.
Fritz
