Does, anyone know if genuine Doherty levers can be identified by distinguishing marks or stampings?
Many thanks
John H
I suspect that the fakes w…
I bought some Lever S/H wi…
I bought some Lever S/H with no marks on them sold as genuine originals!
What era of levers are you…
What era of levers are you talking about ? Norton used Doherty pre-war and it would seem that they must have asked for parts without maker's name.
As far as I'm aware, they can only be identified by the style or, in the case of the A/R and choke levers by the rather well made friction arrangements which are probably the subject of a registered design somewhere or other that I ought to look up.
I suppose they are late 50…
I suppose they are late 50s or 60s they are Ball ended, kind of like what I had on my 1970 BSA.
When did Ball-ended levers appear?
Previously richard_payne w…
These are the ones!
doherty-levers-2-jpg
And also... Attachments…
And also...
doherty-levers-jpg
I now need cable adjustmen…
I now need cable adjustment inserts!
Hi John, Maybe these will…
Hi John,
Maybe these will assist?
https://www.venhill.co.uk/controls-amp-handlebars/cable-controls/venhill-levers/941-006.html
Otherwise, I have purchased some good quality levers from:
http://www.amcclassicspares.com/Cables%20&%20Control%20Levers.pdf
WITH correct 7/8" centers and with or without adjusters as per needs.
Good luck.
Steve
I've used AMC spares (Ste…
I've used AMC spares (Steve Surbey) as well and agree excellent levers.
Villiers Spares (http://villiersservices.co.uk/ ) also do 7/8" pivot levers much cheaper although I haven't seen their product.
Previously steve_adkins wr…
Previously steve_adkins wrote:
Hi John,
Good luck.
Steve
Thanks will check this out!
Previously ian_soady wrote…
Cheers, Ian will check this out too.
If you buy the Villiers on…
If you buy the Villiers ones, let us know what they're like!
Previously john_hall1 wrot…
Many thanks
John H
Well AMAL levers Are the Original Levers and controls for all motorcycles I have the big AMAL MANUEL with them all in, and carburettorsto all marks from day one, every GP types 1 type 2 and type 3 and TT 10 and TT15 and type 27 twin bowl, and type 74/75/76//89 pre monobloc and monobloc 374 375 376 389, and concentric types and carburettor tuning of all types yours anna j
I suspect that the fakes will have them as well......
