Fuel proof paint......
Hey
Can anyone recommend an unleaded-fuel proof paint?
I had my commando tank painted about 6 months ago. I noticed that some of the paint and lacquer has been pickling around the fuel cap. So Iâve removed the fuel cap and scraped away the old paint and lacquer. The plan is to put some fuel proof paint around the cap area, perhaps a hammerite or a primer? When the fuel cap is replaced it will cover the area that Iâm re-painting.
Hey
Hello ,Ben. Well I am looking for some myself .But I have not come across any yet, But I will let all members know when , I do, Hammerite will not do the job as its Oil based paint ,And the Ethanol in the fuel will take it off easly ,every tank I have seen as the same problem , even new cars get the paint coming away round the filler cap over time, , Your Anna J Dixon
@font-face { font-family: "Cambria";}p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Greetings from a nice warm South Australia,
I see its going to hit a massive 6 degrees in London, only going to be 30 deg C here today, 36 tomorrow, ohhh sorry 'orf topic.....
You can use POR-15 US fuel tank liner as a 'local paint' inand around fuel filler caps.
However surface preparation is extremely important andunless you were going to line the tank as well, prohibitively expensive BUT it is Ethanol compliant.
See:
http://www.por15.com/Fuel-System-Restoration/products/12/
And:
http://www.por15.com/quickindex.asp
Good luck!
Rgds Steve
Hey
Hello Ben I have found a fuel resistant clear coat laquer ,proXL from Nu-Agine Paints www. nu-aginepaints its £11 odd , So have a look under clear coats and laquers ,Yours Anna J Dixon
ok well iv found a very good paint that is fuel proof combi couler gerder paint its fuel resistant and self leveling and anti scratch and the red thay do is the same red as my dominator
