Does anyone know where I can get a new bracket that holds the spring clip, for an Interstate left panel? The panel has 3 small holes in a triangle where the bracket was fixed.
Does anyone have one they can sell me?
Andy
Hi, Do you mean the bracke…
Do you mean the bracket that mounts on to the side of the black air box on the 850 MkIII ?
I cannot sell you mine as even though it is no longer attached to the airbox (removed when box removed to go to single carb) one day someone may wish to restore to twin carbs.
I could do you a drawing if that would help, it would be fairly simple to re-create. The spring clip itself is available.
Let me know if this is of interest.
