Gremlins are back
Commando slowed to a halt just as we'd entered an underpass on the A3 over the bank holiday
Bloody frightening to say the least, not a good place to breakdown.
My initial thought was petrol starvation as the engine didn't suddenly stop but ran lumpy for a hundred yards or so, straight on with the reserve tap but she still died
I'm running a VM36 Mikuni which I jetted back to standard with settings I got from Allens Performance,with Pazon Sure-Fire ignition, when the bikes warmed up she runs very well
This has happened twice before when I was running on a Boyer ignition with a single Amal
I thought these were the problem ,and so changed both for more modern alternatives (as above)
I've checked the petrol tank cap breather, clear, I'd only done forty miles on a full tank of fresh fuel so I've discounted that, oil levels OK.
The bike restarted after a few kicks, these intermittent breakdowns are bloody annoying as well as dangerous
Any ideas for what to look for would be appreciated
Steve
When I suffered such things on my Mk 3, it evntually turned out to be an internal break in the wiring to the ignition sensor. Took a fair while to suss that one out. Try fiddling with wires with the engine running. Highly technical I know, but it might just show something up.
Reminds me of the time my clutch cable broke in heavy traffic one morning on Vauxhall Bridge .....
The symptoms sound as if they might be heat related. Something warms up, expands, goes wrong, cools down a bit, works again for a while. I have been there and done that one.
In theory you have already eliminated the ignition pack and the carburettor. If you have not already done so, try swapping the coils. These have been known to short down when hot after having been over-clamped. I know the Smart-Fire kit comes with its own coil; maybe the Sure-Fire does as well in which case forget that idea.
After that, I like Gordon's wire fiddling idea.
The other time I had similar symptoms was when some sealant got into the petrol taps and randomly restricted the flow of fuel.
The lumpy running might be the clue here. It suggests to me the appearance of an electrical problem. I would be looking for a loose wire or another electrically driven chunk that has come adrift and is causing a short.
Top of my check list would be .......is the horn still in p;lace and not waving at passing traffic. If this is ok I would then look at the wires in the handlebar switches. On my Commando, the white wire that powers the indicators has twiceparted company from its soldered position.Both of the aforementioned have shorted out the battery and caused grotty engine performance.
It might be worth checking the leads to the Pazon gear. The connections to the trigger plate strike me as a bit flimsy compared to the rest of it. There was a problem with the first Boyer gear when the Commando enginesvibes caused internal breakages in the pick-up wires. Could this be a repeat???
Check out your coil terminals. These suffer greatly from muck chucked off the road and do need a clean up now and then. Is one of the terminals or spades a bit loose?
I was quite surprised at the green contentsinside my ignition switch when I fitted my Pazon a few years ago. A good clean-up made all the lights suddenly go much brighter. Check the terminals on this switch for loose bits. Some new ones, recentlybeing sold by a BIG NAME supplier,had rivitted terminals which came loose as soon as a spade was pushed in place. Cheap imported junk sold for big bucks......shame on them.
Hello And After You have Done all this it will turn out to be a earth wire from the battery to frame thats at fault Yours Anna J
PS have you tryed out a SU carburettor conversion yet these carbs are more relivable and give a better MPG , with very little of the top speed to contact AMAL Carburettors On the Interweb Yours Anna J
Steve
Have you discounted icing up of the carburettor? This seems more prone now with ethanol added to fuel (which increases the dissolved moisture content) Kawasaki had a real problem with this on their 900 four - a factory recall included fittiing manifold heaters Mike
Thank you all for your ideas, Anna I will check the major earth cable first off as it's the easiest to access, the coils are brand new from the club so I'm ruling them out
The bike has only done roughly twenty thousand miles from new(1977) rebuilt by myself back in 1998 ( I'm a engineer specializing on vintage / veteran car engines) so I'm confident nothing is breaking down mechanically causing partial seizures.
I will take a look at the petrol taps, though relatively new they may be partially blocked as I'd sealed the tank with Wasselâs tank sealant, maybe the ethanol's causing it to come adrift.
I took the main power feed to the Pazon from the white wire near the kill switch (which doesn't seem to work anymore) but that can't explain the two breakdowns on my earlier set-up ie Boyer / Amal where the Boyer box had a direct feed via an isolation switch straight from the battery.
I like Gordon's idea of fiddling with the wires.
I'll report any findings next weekend
Cheers Steve
Cheers Steve
Hello Steve It looks like you may have more than one problem . I would check out the kill switch and earth wires and there is little trick if you run the bike in the dark you see if there any thing aching any where . the other thing with be that Wassel tank sealer . you need to get the Harley Davidson tank sealer , they been making it longer than anyone else , as they Had Ethanol way longer than us in the UK
. yours anna j
Hi all
Spent more hours on the Commando Saturday cured the tacho- drive oil leak, I got a seal from my local bearing suppliers ( part no a 406) it's basically a bog standard lipseal (14mm o/d. X 7mm i/d x 4mm wide cost 50p and ten minutes on a lathe, I will admit that if the original conical thrust type washer touches your new lip seal it will leak( so if you're boring the tacho-housing yourself give it more depth 6 or 7 mm should do) or as I did grind the conical thrust type washer basically flat so it does'nt bind against the new seal
With regard to the gremlins,
Checked earth strap to engine all seems ok , stripped out both petrol taps,clean as a whistle, with no sign of the Wassellâs tank sealant being effected by the ethanol (proud to be English moment, the Union Jack on their logo still stands for quality) three cheers for them
Stripped and cleaned engine kill switch, it would now work, but I've by-passed that part of the loom
And so its redundant
Fifty odd miles ,two-up last Sunday, no major drama's to report, just a nice bimble around the lanes of Surrey, but I will admit to avoiding the A3 like the plague.
Steve
I had a 750 with Mikuni which used to ice up occasionally, very disconcerting. Like your bike it just coasted to a halt and would restart after 20 or so seconds. Never did find a cure.
sam
You certainly have a short or a damaged lead that is earthing your coils. Check your ignition switch these have a tendency to short especially if moist or have a hair line crack in the insulation.
Don't rule out the coils as even new ones can break down. Also check the leads (just buy cable and make your own 100% copper ones its better) oh and plug caps as I believe your bike should not have plug caps with resistors in, check these as modern bought ones usually have resistors in...not good!
Another little tip get a small plant sprayer, put some redex in and spray a very fine mist into the carbs when running at mid power. We we used to do it to clean out carbs prior to racing.
It smokes like hell and coughs a bit but worked for us cleans them out as gumming up is a real problem with our old bikes due to the bloody dreaded methanol.
No one has yet mentioned the arch gremlin, the dreaded lucas ignition switch. Hot wire the entire ignition loom, battery to ignition supply. This counts out the loom problems. Have you tried swearing at it yet? That allways works!
Happy Huntig,
Boo.
Hi, in addition to Boo's comments I had similar on my 72 750...Interpol / police part of the loom with purple/white wire ( belive a kill switch option ) with an intermittent short to frame near the 2MC capacitor...random event till I found it. Defo think ignition issue...good luck.
hi all
the commando disgraced itself again on the way to brooklands yesterday, both times on the dreaded A3, the same old gremlin reappeared loosing power before coming to a halt, only to restart after a prolonged bout of kicking and swearing.
This seems to happen only if I try to get a move on and I'm now convinced it's fuel/ethanol/carb related ie icing and not an electrical issue
I cupped my floatbowl to check it's temperature and was surprised how cold it felt, when compared to my mate's single mk1 amal, I'm wondering whether the rubber inlet manifold is isolating the carb from the engine too well, stopping any heat transfer
My next step will be to bridge the rubber inlet adaptor. by rigging up a so called heating element from the aluminium inlet manifold to the carb , with a few coils of copper wire wrapped around the carbs body this should hopefully dissipate some manifold heat to the carb and raise it's temperature enough to stop this problem re-occurring.
STEVE
Hi Steve, I think that a gradual lose of power is more likely to be a lack of fuel than an ignition problem. You are unlikely to get carb icing if you are running an air filter particularly in the current dry-ish weather. Carb icing will manifest itself as a stuck throttle after a period of open throttle work. I would borrow another carb to try and isolate the problem. You could have a reduced flow of fuel into the float chamber, enough for poodling around but not enough for open throttle work. Try this, remove the float bowl drain plug, place a measuring jug under it, open the petrol tap and measure how much flows in say one minute. Now lets say a Commando does 60 MPG at 60 MPH you need to see a sixty'th of a gallon in the jug in one minute 1hour = 1 gall, 15 minutes = 2 pints, 7.5 minutes = 1 pint, 3 minutes 45 seconds = half a pint etc. Any less than that and you are not getting enough fuel at large throttle openings.
When the bike has died on you, you will have to wait until the float bowl has filled again before it will start. Measure the feed rate with one tap open and then with both. You could measure the flow through the taps first if you want. If that is satis then the fault may lie with the float needle mechanism.
My money is on lack of fuel supply
Yours
Gripper
I would be extremely surprised if it were carb icing. My 99 is very prone to icing, but the conditions required are air temp at or below freezing and damp or wet conditions. The symptoms are running rich, loss of power, black smoke and sticking throttle. The sticking throttle is such fun on icy twisty roads... It clears if you stop the bike and kill the engine and wait for a few minutes for the engine heat to melt the carb ice.
Your symptoms do sound much more like fuel starvation. We have mentioned the fuel tank breather, haven't we?
Gordon.
HI all
Gordon thanks for the reply , I double checked the fuel tank breather by running with the cap open, after a fairly brisk blat down the road all the usual symptoms were back, surging power , stopping ,etc, etc, only to clear before the next episode of bad running. so I'm discounting the tank breather,Thanks for the icing clues, I have not had the throttle stick open ,black smoke etc, so i'll put the heating element on hold at the moment.
I will certainly check the fuel flow rate as David has mentioned, as the petrol pipe feels strange to the touch, although fairly new if you try a gentle pinch between finger and thumb,it seems as if the inside is detaching from the outside, possibly breaking down and restricting the fuel.
I'll keep you informed.
STEVE
Fuel lines are very suspect. I fitted a nice new stainless braided one and it quietly dissolved then poured petrol everywhere. Back to the boring black Halfords fuel injection pipe - works a treat. If your fuel line feels spongy, I would change it sooner rather then later. Gordon.
Hi all
I got to the root of the problem this weekend, nothing to do with the carb icing or bad electrical contacts, the petrol pipe which I had purchased from classic runners of croydon which used to be a good bike shop some years back, turned out to be more like car radiator overflow pipe, totally useless for fuel as the insides started to breakdown causing all the troublesome gremlins.
I'm bloody annoyed that I was sold something so unfit for purpose, which could have had such terrible outcome,If you think I'm exaggerating feel free to stop on the A3 in the underpass near tolworth towers.
purchased some new fuel pipe from clas ohlsens, it's marine type fuel resistant and cheap @ six quid for 5 ft+
i'll try and download a picture, this is with the pipe split open
STEVE
imag0727-jpg
glad we got to the bottom of that one. I use "TYGON" fuel pipe normally used in the light aircraft world it's clear, though a yellow colour and does not go hard with use as does normal plastic tubing. Not cheap, 2 metres cost me about 18 quid but I reckon it should see me out, available from a small outfit near coventry airport Google reveals all
Even light aircraft have been having fuel problems, despite expensive aircraft quality components... You should see pictures of Gypsy Major carbs pretty much eaten away with modern fuel.
Glad you got the problem fixed. It's astonishing how current petrol dissolves fuel lines. Your old one looked like it was made from rat intestines- which would probably have done a better job. The cheapy Halfords fuel injector black flexible tubing has been on my bikes for years now and I have had no problems at all, other than the brief interlude with the nice braided stainless pipe that failed. At least it didn't cost me - it was a gift from a well-meaning friend.
The website encountered an unexpected error. Please try again later.
