Is it worth getting these serviced, new seals/pads etc and where would be the best place to send the caliper or would it be better to fit a different caliper with adaptor plate and if so then where best to obtain that?
Many thanks.
Henry
If you mean the standard…
If you mean the standard Lockheed calliper as fitted on the Commando, then they are easy to service. There is nothing special required other than the peg spanner to get the cover off.
https://andover-norton.co.uk/en/shop-details-2/16200
The best description I have seen of how to do it is:-
https://www.motorcycleclassics.com/classic-motorcycle-repair/rebuild-norton-commando-disc-brake-caliper/
The standard calliper is perfectly adequate but I would heartily recommend the 13mm master cylinder conversion if you have not done that already.
