The 850 MK3 starter motor (Prestolite and its clones)
My original submission of an article on this starter system to Roadholder was way back in 2016 (No 341)  I was intending to issue photos with the narritive but it was published before i got around to sending them in!
So now with all this covid b******s about i thought i would do that now.
In between then and now i have converted a few new Harley starter motors for customers and also upgraded the original prestolites for others wanting there bikes to remain looking standard, but to actually start the engine!
Photo 1 is the brand new  5780BN starter motor for certain models of Harleys, made by WAI or World Power Systems, A USA company, it says so on the box.
I bought this from M & P Accessories (via ebay) for  £84 delivered to my front door today. A common ploy to upgrade your old prestolite is to use the 4 pole frame from one of these starters as a replacement for the 2 pole prestolite frame, This will work but isn't the best option. Incidentally There are dealers who are punting out these motors (5780BN) on ebay for  £125 advertising them as 'Norton commando 4 pole conversions' or words to that effect. It did occur to me to be a way of making money doing the same (buying low and selling high) I prefer to do things differently.
Photo 2 is the 5780BN starter stripped, the difference between this motor and the original prestolite is the different drive gear, drive end plate, through bolts, 4 pole frame and brush plate and needle roller bearing in the brush end cap. The photo also shows the brushes held in place with s/steel clips.
Photo 3 is the 5780 BN rotor modified to fit a 6203 2RS bearing and a new drive pinion to suit the Commando drive train, also in the photo is the new drive end plate.
Photo 4 The completed, Commando ready, modified 5780BN starter.
If anyone is interested i'll post the modifications needed to make the original prestolites work better than new.
Thanks for sharing this with us all.  I'm sure there are a lot of members who make useful modifications that need sharing for the benefit of other members.  Perhaps a new category could be created in the Technical section for members to add their own ideas.
Well done.
Hi Peter,
I would be very interested in this modification to the 5780BN starter motor for my MK3 rebuild. You said M&P had these, is this still the case as i cant find them now ?
Kind regards,
Ian
Ian
On ebay type '5780BN' into the search box. Brings up loads of hits, forth or fifth one down is the M&P one. Its got a picture of four different types of starter motor. Wish we could get them at the prices they sell them in the states, first one on the list was for just over £50!
The M&P price is £83.99    20% of that is tax £69.99 before VAT   M&P probably get them in for £50ish so the £125 others charge is a bit much!
Don't hesitate to ask about these things, Ive got nine of them in a cupboard, all overhauled/converted!
Hello Ian again
Yes i do sell them, the price varies depending on what type you want.  Obviously converting a brand new 5780 BN gives you a brand new motor, using all new bits. £210 plus p+p
I think this is what CNW sell, a converted 5780BN for over $500
An overhauled/upgraded  original prestolite if it is the customers own motor and he/she wants it upgrading, it all depends on the original motors condition. I have overhauled and upgraded motors that others have thrown out for scrap. One i had to use a copperhide hammer to remove the rotor from the frame it was that rusty!
All things being equal, I thought i would list the things i think are the first to do in order of importance.
1 make sure the charging system and battery are in first class condition and are doing what they should be doing
 Fit heavier gauge cables to the starter and battery/solenoid
3  Make sure all switch gear is in top condition
4 If using an original spec prestolite, service the damn thing! The original spec prestolite has a built in failure mode, that is after prolonged use the rotor will wear itself into the drive end plate and result in the rotor windings contacting the end plate and performance then drops off. The mod outlined in 5 stops this wear.
5 If wanting to use a prestolite (to maintain the original appearance) Fit it with rolling element bearings as outlined in the technical pages on this site. A chap called Jim Bush did it and said it improved the starting no end. Even a 2 pole motor thus modified will start the engine with ease.
6  as 5 but fit the 2 pole frame with 4 field coils. Use a modified 5780BN or one of the Dynodave / WOSP /Holland Norton works /CNW motors falls into this category as well.
as an aside i have used 5780 BN internals to resurrect spare prestolite frames and to replace dud prestolite rotors  I will consider part exchanges as well, dependant on condition...
In reply to by peter_shand
Hi again Peter,
I have always maintained my old Prestolite motor, stripping and cleaning every couple of years. I stripped my MK3 over 3 years ago and am part way through a full rebuild and knowing what the starter motor is like have been considering either converting to 4 brush or finding an alternative unit. Reading your description of the mechanics of the motor i can now see its weaknesses.
Looking at the pictures of the converted 5780BN it doesnt look that much different to the Prestolite and i`m not looking for absolute originality with my rebuild as some other sensible mods/upgrades will be done anyway. Some of the other alternatives from well known suppliers look a bit to modern compared to yours, especially with yours having the black body.
As far as my wiring goes it will all be new with heavier starter cables.
Does the 5780BN have the same amount of teeth on the drive gear ?
Definitely interested in buying one of these.
Kind regards,
Ian
Morning Ian
Yes, it has the same tooth count as the prestolite, Your thoughts echo mine regarding the look of the Dynodave / Wosp / HNW starter.
Hi Peter
I have just bought a Mk3 Commando, it’s a US import from a dry State, no rust!
 Can you upgrade the starter motor please?
My email is garyallenhome@btinternet.com
I have added some photos, it turns freely and is clean
I look forward to hearing from you
Best regards
Gary Allen
Hi. I am interested in a replacement starter motor for my 850mk3.
Not sure how I contact Peter but here is my email.
rodwell1957@gmail.com
kind regards.
Mike.
Hi Peter,
Would you like to sell me a starter motor or modify mine as it's in a poor condition due to water ingress. I did the 4 brush conversion and it does work but I suspect it wont be long before it fails.
My e-mail is milof124@yahoo.co.uk  the names Marcus
I found your 2016 post on the this subject: https://www.nortonownersclub.org/node/3337
And I have to say the prospect of removing the kickstart is very appealing (I'd like to move the footrests back without going full-on rearsets). Has your confidence in the starter motor mod stood the test of time?
Morning Stan
I made and fitted the rearsets at the beginning of 2017 and since then the kickstart has been blanked off. I have toured Switzerland in 2017, went to the Austrian International rally in 2018, the Holland International rally in 2019 and had booked for the Portugal rally in 2020 so I think you could say it has stood the test of time.
The photo shows the brake lever in its new position, Right in the way of the kickstart!
Hi Peter,
Interested in reviving my 850ES's ability to start on a button. Knees clapping out. Have a belt drive and no starter at present but have all original clutch/drive etc stuff to revert to original.Happy to do that soon and i was looking at a Wosp starter but your post has led me towards your route. Obvious financial gain (to be spent on other bits of course). Reading your post correctly, i hope.
Looks like i need to mod shaft bearing. Commercially available and no prob. You indicate a change of starter pinion needed. Are you suggesting using one of original starter which i would prefer not to do or obtaining a new one? Are they commercially available?
John
In reply to by john_brooks
Hello John
You have a few options to consider. 1.Send me your old prestolite for modification. 2. Buy  a replacement starter (either modified 5780BN or the Wosp). 3.Send me a new 5780BN for modification 4. part ex your old motor for one i have a stock.
study the pictures of the WPS/WAI  starter in bits and you will see that the drive pinion is new and yes i make them. If you have the needed skills and equipment to do the conversion i can supply one.
Hi Peter,
thanks for info re adaption. i have bitten bullet and ordered starter. i reckon i am ok to convert thanks, but would find pinion useful. Just one other point, use end plate off new starter i assume?  Would you be good enough to push a price across for pinion and how to pay.
gmail will come to my phone.
nor2hon1@gmail.com
many thanks
john
Morning John
If you are intent on doing the conversion yourself you will need a new drive end plate to suit the 6203 bearing. Cut the 5780BN Harley drive pinion off the rotor (it cannot be used its too big) . Turn or grind (I use a toolpost grinder) to get the shaft down to fit the 17mm bore of the 6203. drill the end to take the new pinion. put pinion into the shaft and radially drill through for a 4mm dia pin to lock it in place. Take pinion out of shaft and then heat treat it, clean up and refit pinion using Loctite 638 and the 4mm pin.
Assemble modded rotor into the new drive end plate with the 6203 bearing, insert into frame and assemble the brush end and cap. You will also require two new through bolts (the long ones) You can either buy new ones or modifiy the ones from the redundant 5780BN
I will PM you with details
Hi Peter
Would you adapt a new motor  (5780BN) for me and if so what would you charge to do the work?
My email:    graham.miller@btinternet.com
Kind regards
Graham (Norton 850 MK3)
Hello Peter SHAND, we met during the inter rally in Austria, on a parking lot where there were several bikers parked a green space and a small shop, it was on the road going towards the iron mine. I recognized your name on the support of the footrest, which I had taken in photo.
In reply to by francis_vidril
Nice to hear from you Francis, I was with a friend (who was on a new Yamaha) and if it was where i think it was we were on our way back from the Redbull ring where the rally was.
My friend was averaging 80 Miles per gallon for the trip, My commando pipped him at 81 m.p.g.  Much to his disgust!
Regards and stay safe
Thanks for that Peter.
Apparently my starter motor has the Harley 4-pole guts (Andy Holmes did it and I later bought it back). It currently serves only to fill the hole. Remembering how "well" they worked originally, I just use the kickstart. But being able to remove the k/s lever changes the calculation entirely. I'm going to look inside my starter to see what I've got and it's very lilkely I'll be in touch.
One more question if I may: your 2016 article describes a modification to the starter gear for the sprag clutch in which you cut down a needle roller inner race (like these https://www.wychbearings.co.uk/needle_bearing_inner_rings.html ). Given the amount of metal you remove, surely you've gone thru the hardening and lost the precision ground surface. Wouldn't it be more direct and just as satisfactory to turn a bit of EN8 (or EN24 if you're feeling flash) bar to size and heat treat that?
Hello Stan
I did use those inner rings for a few of these sleeves but I now use the inner races from scrap bearings from industrial gearboxes. Made from the same material and through hardened (and less material to remove and free)  They can be turned with sharp carbide tools and then finish ground using the toolpost grinder. No heat treatment needed as it is still hard.
When you next have the engine sprocket off assemble it with the sprag and drive gear then look through the tapped holes (that you screw the sprocket puller bolts into) to see what angle the dogbones in the sprag are at. If they are almost 'upright'  the sprag is in danger of destroying itself. Much better if they are at an angle. The sleeving increases this angle as the drive gear 'snout' is then that little bit bigger.
Peter,  did you receive the PM I sent you. I can't find it now. I've no idea how the pm thing works. !!
Cheers. Hans.
In reply to by hans_taylor
Hello Hans
Yes I did get it and I replied,I think , Ill check later today!
Morning Hans
If you send a PM through the website, click the little box that sends you a copy of the PM, that way you then have a record of what you have sent someone. I,ve just this minute figured out that is why i can't find the message i sent you, I didnt copy myself into the message.
Check your email, it should be there.
Evening Gary
Yes i can do that for you
PM sent
regards
You wont regret this Gary, Peter did mine last year and its a fantastic job. He has re-engineered the motor to what it should have been, why put an aftermarket item on when you can have this done.
Peter is an absolutely fantastic engineer and wizard when it comes to Nortons.
Kind regards, Ian
If you refer to my nippondenso based dynodave/atlantic green  item, Here is the difference. All the prestolite style mods still have the same armature. This prestolite armature is a SINGLE layer wrap. Of course the added brushes and coils will help "some".
Yet the ND two layer wrap armature provides a measured 40% increase in magnetism per amp of current draw. I have never seen a twin wrap armature for the prestolite or its clones. So to me, even the upgraded prestolite design continues to be inferior after all that work. I own a NOS prestolite that works just fine on my MK3 with a good charging system....
Since 2004 I have personally built and sold over 1300 of mine with extremely few complaints. While I should be honored that WOSP has stolen my design, I still can sell mine as I have kept my price the same since day one but WOSP has just gone up 10% ..
Does WOSP know anything about a NHT commando MK3? and  give phone support?
I own 4 of them, one as a complete basket case from parts I assembled and made running since 1995 and one with 5 original miles/never registered or driven.
One thing I do recommend is a better charging system over a starter. It does not matter how good the starter is if you run a constant semi charged battery.
A tiny slimline featherbed battery , a regular commando battery and a pure stock MK3 battery will all start a commando if fully charged.
The main reason I was asked to do my starter was for the rusty destroyed armatures that were not available since prestolite discontinued support in the mid 80's.
$375 = £285. Plus shipping and taxes.
https://atlanticgreen.com/starter.htm
I found the details of the 06-4791B starter some while ago. And it reads very well. NipponDenso internals, gearing reduction thru 9 tooth pinion and lighter too. But Peter Shand will fix up your old Prestolite far cheaper and, on the evidence we have, it is plenty good enough. Maybe squeeze in a 20Ah battery if it's a bit reluctant on cold mornings.
Well I,ve just replaced my WOSP starter. New in 2019, it blew up after only 13,000 miles last month. The commutator disintegrated on startup and the sudden stop broke my reliable Aliexpress sprag, luckily with no damage to the engine sprocket or the starter drive gearwheel. This is my third failure of this type starter motor although none appear to have genuine Denso motors as the original Dyno Dave version.
Previous starters of this type from Norvil and RGM have both failed in service, the RGM under 10,000 miles with blown armature windings and a badly worn drive pinion. On a Spanish trip the Norvil started the bike OK then instantly turned into a 60,000rpm electric motor which blew up with a big clunk.
In all cases I managed to get home on my e start only Mk3 with the help of hills or push starts.
I,m not remotely interested if an armature is single or double wrapped, how much magnetism it has or whether the vendor knows anything about Mk3 Commandos. I just want a starter that works like on my Japanese engines. The Norvil and RGM models are no better than the WOSP version in my experience, in fact they,ve both failed at a lower mileage.
Bottom line is these are not up to the job on my bike so I,ve had my original Prestolite armature and commutator rebuilt by Robson and Francis. It,s now fitted to a new 5780BN four field coil case and brush set using the original end caps. The front drive side has the original bronze bush which is still a perfect fit, the rear I fitted with an needle roller and inner ring back in 2008.
Hopefully I,ll have a starter that,ll outlast any of the pricey Dyno Dave type which are close to £500 these days from RGM and Holland Norton Works. The WOSP is better value at around £300 but a similar unacceptable working life.
Morning Neil
Your description of your prestolite says it still has the drive side bronze bush. Make sure that the end float wear is addressed so that the rotor windings don,t contact the drive end plate.(this is one of the three built in faults of the std prestolite) Either add a spacer or mod the drive end plate with a 6203 2RS bearing. The second built in fault of the std prestolite is a result of the fact they weren't made very well! The commutator is very often out of true to the shaft journal. This became apparent to me when i obtained a brand new OTS prestolite, never been fitted, never been run.  Upon taking the starter to bits to fit it with the bearing modifications i trued up the rotor to the commutator end shaft and noticed the commutator was 7 thou out of true. This explains why i,ve seen loads of brushes with wear patterns on the sides where they have been oscillating in the brush holders.  The third fault is that they were never sealed from the elements and the rain of petrol from tickling the carbs so they go rusty inside!
I have never laid hands on one of the Dyno Dave/wosp starters, If you can send me the remains of your blown up ones (At my expense) It would be interesting to see whats what with them.
Many thanks for the nice comments
FWIW the only blown up armartures I am aware of, are from a sprag flip over lock up. No armature can withstand 35,000 rpm.
per NW " The commutator disintegrated on startup and the sudden stop broke my reliable Aliexpress sprag, luckily with no damage to the engine sprocket or Peter Shands excellent sleeved gearwheel mod. "
You should note the sprag failure lockup is what causes the motor to spin up to explosion. not the other way around you describe..
The motor alone has not blown up from it's own unloaded free wheeling RPM. However all motor manuals suggest a maximun of 20-30  seconds of continuous cranking use with an adequate cool off period before reuse. ANY STARTER  The commutator will likely fail if super heated mercilessly.
Strange you brits have so much trouble? here in the US a lifetime warranty is almost never needed or used .   Sprag lockups are somewhat rare, but do on occasion happen.  A rebuild at minimal cost is provided.
On sprag blow ups, I request examining the 3 components and they are almost always extremely degraded leadiing to what I call "slip[ and fall" of the sprag dogbones..
US price high? sorry now you know how we feel getting your parts....
P.S. I NEVER sold one of my starters to RGM....
In the interests of informed discussion, I'll add a comment here.
I have no direct experience of the DynoDave starter, only what I read on the Atlantic Green site. My main experience of the Prestolite starter is from the original setup some 40 years ago when I just gave up and used the kickstarter. But using those 40 years of accumulated knowledge I have now built a bike with the 4-pole internals, mini solenoid, heavier cables and 16Ah battery - which seems to work ok. And I'm minded to have Peter Shand modify it so it's reliable enough long-term to remove the kickstarter.
Doesn't have to spin up like a Honda, as good as a BMW R100/7 will be fine (a bit sluggish at times even with a 25Ah battery). And that leads me on to the NipponDenso option for the BMW (apparently based on the motor fitted to Toyota pickups). You can have the original Bosh starter refurbished for £110 or you can buy the ND replacement at £329. Of note is the use of planetery gearing so that the motor spins quite a bit faster, does actually crank a boxer twin like a Honda and is reported to be superb.
I don't know what £285 plus shipping and taxes will actually translate to when it arrives on UK shores, perhaps you might enlighten us David. But it's in the ballpark of the BMW item and, if it really does transform an £8000 Commando, not outrageous. More to the point, the Bosch starter started a BMW fine in 1976 and refurbished one will go another 40 years so why spend more, although clearly some do. But restoring a Mk3 to how it was in 1975 is hardly desireable so some modification is definitely needed.
I agree with your point about the sprag clutch being the likely culprit in spining the starter to destruction and a Prestolite would be similary wrecked. And there is a case to be made that spinning the motor "with vigour" will actually give the sprag a slightly easier time.
For me, the jury's out, but I will go the Peter Shand route because 1) Peter has been very open about his changes, sharing the details so anyone so minded could do it themselves and 2) it is cheaper.
For information, my original replacement starter was designed at the request of a friend with a MK3.
His motivation was an expensive "rebuild" sent to California for a 4 brush/coil up grade. It cam back running the wrong direction, At further local cost to fix that problem it final worked. We ended up taking it apart to discover the starters actual internal condition. The condition of the core and rebuild was rather poor and not close to the price of all the work done.
In the final analysis the lack of real prestolite replacement parts, specifically the armature, was the motivation to move forward. Prestolite new components were terminated around 1985 and all inventory of Norton starter parts was liquidated. It would appear" British Only" in Michigan bought a large amount of the inventory. In 1994 British Only was selling NOS complete starters and I bought one. to use on my own basket case MK3. For 5 years/seasons I rode with a pure stock (except Lucas Rita) bkie and it was fine and always started and ran. The first YUASA battery finally died and the bike was pushed aside.
In 2004 the new starter issue was raised and my friend wanted something better so began the ND replacement to overcome parts unavaiIability.   In reality my starter, if real nippondenso part were used, if available,  the starter would likely cost $1000.
So the current prestolite "upgrade" is doing  it's job using chinese arnmatures (probably) .
Here in the US, for retail price, wearing armature gear could receive a new armature for the cost of mail. In europe,  the dealers probably make more money than I do as the builder.
Your british woap starter probably uses similar chinese parts. You get a 1 year(1 season) warranty?
So after 18 years and 1300 of my bolt in starters, conversion for your starter is still based on currently available harley chinese parts and lots of hand craftsmandship.
Interesting that both my clutch rod seals and starters were offered to NOC but "crickets" was the answer?
Afternoon Chaps
I have just trued up Gary Allen's prestolite rotor in the lathe, ready for machining to fit the needle roller and 6203 bearings. This rotor was even worse than the one i spoke about in a previous post. So badly was it made, that the commutator is 13 thou out of true when the rotor is clocked up to the shaft journal. Not only is the commutator out of true but the rotor laminations as well. I even filmed the dial gauge readings so i have a record of what i've found! These motors cannot ever have been balanced when they were made (either statically or dynamically)
Maybe prestolite regarded balancing the motor to be irrelevant as the engines they were to be fitted to shook so much!
I must add that this particular motor has done no work (or very little) at all as it still looks brand new on the inside.
The new 5780 BN motors i convert for Mk3 use are far better made than the prestolites and their rotors are dynamically balanced. The brush plate is made from glass reinforced sheet so is much stronger than the paxolin type stuff the prestolites use. Incidentally 5780 BN internals can be used to rejuvinate/repair dud prestolites if you can fit the 5780 rotor with the MK3 drive gear.
Good Morning Peter,
My starter sometimes works but more often just makes horrible noises, I suspect the bushes are worn as there is a fair amount of play apparent, please could you contact me regarding purchase of one of your modified starters?
My email is timm.nicholls@googlemail.com
Thanks and regards.
Tim.
If you log-on to the website and click on Peter's name at the top of the message a 'contact' option should appear whereby you can email him ... .
HtH
Hi Peter,
Being a new member it was interesting to read the upgrade you can do for a MK3 standard starter motor,as i have bought a new 4 brush Prestolite motor how can i have this upgraded with a the bearing fitted to the front plate,could you help?
Many thanks Graham davis.alison04@gmailcom
Just a quick note to say how impressed I was with Peter Shand's work on my Prestolite. I looked at all the alternatives and concluded Peter's option was not only the most viable but by far the best way to address one of the Mk3's shortcomings. His engineering enables the unit to work reliably whether you are starting from cold or otherwise and maintains the bike's originality. With proper bearings installed the starter motor should provide years of reliable service giving you peace of mind. Highly recommended!
Gavin Thomas
