Dominator kick start
I recently fitted a new kick start shaft, now when I kick it over the back wheel rotates and the kickstart won't return properly. I've had it all apart again and checked that everything is ok ( which it appears to be) but on reassembly it's exactly the same.
I have run it up on the stand and set it to a very fast 'idle' selected top gear and run it for about 5 minutes and it seems fine in as much as the kickstart doesn't try to move.
Any ideas please?
Hi Peter.
First thing to think about is are all the parts used genuine Norton, including the gaskets, which act as spacing shims. The end-float on the kick-start shaft has to be accurately measured. Too little clearance and the gearbox may lock up. After removing the kick-start spring, I had to ream the inside bush and the kick-start bush in the outer cover because the tiniest amount of swarf stopped the kick-start shaft returning to 12 o clock.
Hope that helps
Hi Peter.
Found my notes: with (genuine Norton) new gaskets the minimum end float for kickstart shaft is
.010"  (10 thou) and max' .020".
Shim(s) I used are from early Commando Isolastics:
060775 = .005", 060776 = .010", 060777 = .020", 060778 = .030" (unlikely).
You may have to reduce the OD of the shim so it fits snugly at the end of the kickstart shaft inside the "stops" on the inner cover.
I set the magnetic base on the DTI (Dial Test Indicator) on the hydraulic ramp to get the measurements.
Method: without a gasket fitted to the inner cover, shim kickstart shaft until resistance is felt. Dismantle and fit a new gasket. You should find the new gasket has provided the required clearance. If not, start again.
Keep a stock of new gaskets!
Thanks for the replies Tim, the odd thing is, and therefore I believe the cause of the problem, that I have no endfloat at all on the kickstart shaft(?). I now have the kickstart returning ok but the sprocket is still turning and feels a bit tight, and that's without the outer cover being in place.
Tim, I've found the issue and fixed it ! The steel kickstart top hat bush in the inner cover was not fully home ( not something I had touched), I warmed the casting and seated it down and all was ok , end float on the k/s shaft and everything working as it should. Took it apart again removed the bush cleaned everything and put it back with a dab of loctite. Shimmed it up and now ready to fit.Top hat kickstart bush
