Hello fellow Nortonists--it is some months since I did anything to the Navigator project, work and having the heads off two other bikes etc,
I am about to start wiring the bike up, I have the two old coils--they were mounted one on top of the other another under the front of the tank, A previous owner had welded a bracket across the two tubes. I have cut it in two and plan to keep the coils where I found them, They are 6 volt Wico pacy items--is there any difference to be observed using them with a Boyer kit as I would two Lucas coils?
My electrical systems tend to all the same--I use regulator rectifiers. I have one I bought off the net to regulate the 200watt single phase stator (Lucas stator Wipac rotor) there is a loss in power I gather but--this rotor seems to be capable of kicking out more power that the three phase ones on the Triumph,
I have fitted a 7 inch front lamp and have a halogen bulb. I am pretty familiar with Brit bike electrics (but my soldered joints often let me down),
Is there anything I should know on the oddities front--I can half remember there being something about the coils.
Also--if anyone wants my old advance retard and alternator stator they can have them
cheers
JPA
Thanks Uli
Do you have a number for the biggest 12v battery that will fit into the battery carrier?
Also--how did you seal around the alternator wires coming out the back of the primary chain case. My newer (1970s) Triumphs have rubber boots etc--my older one (1960s) takes creativity with silicone sealant.
The Norton cannot use a rubber boot as far as I can see--what did you use?
JPA
HiyaThe coils were…
Hiya
The coils were piggy backed under the tank originally, they were bolted to two tabs on the frame.
I used black silicone where the wires exit the chaincase, but think the club sells the rubbers. I bought some Lucas style bullet connectors but they are as hopeless as they ever were and I am changing them to the properly crimped plastic coated connectors as used on jap bikes.
Which headlamp did you use? I’m still looking for a 61/2 inch one ( I have the smaller earlier one to swap)
i used a motobatt battery the number is another thread somewhere if you search! ....... https://www.nortonownersclub.org/node/7206
dan
Hello Dan, Thanks for…
Hello Dan,
Thanks for that--there seems to be two that would do
I had an old Lucas 7 headlamp so I used that. I have a BSA front end,, home made silencers and it it never I suspect going to be a standard bike The same one as all my other bikes (or most of them--I think the Rickman's shell is from an early 1970s Suzuki),
JPA
JPA
Happy new new year to all in…
Happy new new year to all in the Norton owners club and motorcyclists everywhere.
I have got some wiring done this holiday but if I touch the Norton--something happens to another--The BSA's rockerbox started pouring out oil. Then--when I fixed it-- one of the Triumphs stated the same thing.
I have been fitting a brake light switch and have seen another drama unfold.
Still we slowly advance.
to All
JPA
John,
you use a pair of 6 volt coils wired in series which makes up 12 volts of resistance .
This is how I wired my Navigator.
