I need the above for an early slim line 99 Domi. My existing diagrams do not have any referance to the colour codes of any of the wires. As a novice at maintenance this would be a great help!
Hi David, I believe that t…
Previously david_culf wrot…
David
I can supply a loom kit for any altrnator bike with correct colours, and colour chart and all the bits see question in heavy weight twins. or see the website aoservices.co.uk
Thanks Al Osborn
Hello Rob, Many thanks for…
Hello Rob, Many thanks for reply and the diagram. Unfortunately this is very similar to one I already have, and this requires me to make assumptions as to what the letters next to the wires refer to.As a novice I do not want to make a wrong guess, thanks once again Dave.
The letters next to the wi…
The letters next to the wires indicate the wire color(s). It is pretty straight forward:
B=BLACK
W=WHITE
R=RED
N=BROWN
U=BLUE
etc
So a wire labled BW would be black with a white stripe
Or a wire lablec NG would be a brown wire with a green stripe
And so on....
I'm sure that you will figure it out after looking at it.
Good luck
Hi David, I believe that the attached file is what you need, Regards, Rob.
064-jpg
