Wipac Light switch wiring
I am about to manufacture a new wiring harness for my Navigator.
I used the diagram by Tony Ripley an altered it from Electra to Navigator. ( without electric starter)
How do I wire the Wipac light switch?
There are nine terminals. Which wire goes where? Two wires are already soldered to the switch by the previous owner.
Electra-Circuit-Iss-4.psd
www.norto
Ulrich, The wires are not soldered to the terminals of the light switch. The wires from the loom terminate in a connecting block which is a push fit unto the terminals of the Wipac switch. I don't know where you can get this terminal block (you need two of them -one for the ignition switch as well). Al Osborn is your best bet.
Superb wiring diagram-both the TR original and your amended version. I hadn't seen it before.
Patrick
I know this connecting block goes with the switch:
http://www.classicmotorcyclespares.com/index.php/default/electrical/wiring/bsa-wiring-harnesses/bsa-c15-b40-3ta-ignition-switch-socket-1728.html#Wiring
But the holding bracket for it is also missing.
I do not wire the ignition switch on top of the lampshell. I rather use a Commando switch with key which goes into a hole in the right backside of the lampshell. The previous owner had positioned a key switch here. So the ignition/emergeny switch is only decoration without function.
My question was what wire goes to which terminal?
img_20160807_165317865-748x800-jpg
Ulrich, according to my notes of 25 years ago i numbered the pins 1 to 9. The wiring on the light switch is ;
1 feed to headlight dip switch
2 tail light and speedo light
3 pilot light
4 disconnect- was orange wire from alternator
5 yellow wire link to ignition switch- not needed by you.
6 resistance wire - not needed by you.
7 link wire to terminal 1
8 live feed from battery (ignition switch in your diagram)
9 live feed from battery (ignition switch in your diagram)
My notes don't show which pin I numbered as 1 but looking at the picture of your Wipac switch the soldered on leads would probably be pins 7,8,and 9. but test first on a meter unless someone can come up with a better description.
Have you tested your switches? Wipac switches are deceptive as they can click quite nicely and give the impression of working. I have found that in many cases they often don't work because of corrosion on the inside of the switch.
Thanks Patrick!
THAT is the info I was looking for!
I have not tested the switches yet.
The bases with the pins are the same for light and ignition switches.
Hope at least one is working!
I just ordered the sockets for the switches.
In the diagram I added the terminal numbers according to Patrick?s list.
Hope I got it right. The number one terminal is the one after the cut off terminal on the switch. So the soldered wires are on terminals 1-3.
