I have an irritating leak from the laydown gearbox on my 1950 ES2. It appears to be emanating from down the kickstart shaft. Although this topic has been covered on the forum, it seems to deal with the AMC 'box. My parts book shows the kickstart shaft as having what appears to be a couple of grooves in it but no sealing rings. Could I have overfilled the gearbox, or "do they all do that"? Seeing it is the ONLY place the bike leaks, can anyone suggest a cure/improvement before I get the spanners out? Thanks,
Adam
Adam, no one has replied.…
John, thanks for that, I w…
John, thanks for that, I was starting to feel all alone with my affliction. It sounds like a fairly involved series of mods, but worth it. A job for the winter, I think.
Adam
Adam, sorry I confused you…
Adam, sorry I confused you. To stop oil leaking from the kickstart, you only need to widen the one groove, and insert o ring. Takes a couple of hours and the pool of oil under the bike stops.Trouble is you see other things that need doing, then the bike is in pieces before you know it.
Adam, no one has replied. Maybe you have the only laydown box that still has any oil left in it. When I bought my ES2,the seller claimed the gearbox never leaked a drop.There was about one ounce of oil in it,and some solidified additive. The kickstart was originally sealed with a cork washer between the shaft and bush,pretty hopeless really.The kickstart shaft is below the correct oil level,so leakage is assured.I enlarged the second [outer ]of the two grooves with a grinding wheel as I would imagine the steel is hardened.I used a t&c grinder but a toolpost grinder on a lathe would be as good.Do the outer groove as the inner groove coincides with the drilled cavity inside.Make the groove the correct size for a 3.25 series o ring, fit the oring, not too tight or the spring wont return the crank properly and leakage ceases .Fit a sealed bearing to main gear, tight bushes to the selecter shafts,a tight bush to the main gear and the oil will stay in the box. Mine doesnt leak a drop ,there is one drip a week from the primary case, and thats it.
