Hi,I'm struggling to find an standard size 79mm x 1/8 oil ring for my piston,could anyone point me in the right direction?
Many thanks
Bob
Try Cox and Turner in Yeovil
That's a good result then…
That's a good result then Peter, sounds worth adding them in the Services tab.
You probably know this but I…
You probably know this but I am pretty sure these are the same size as BSA B44
Performance Engineering Services (Mark Cook) should be able to help
I needed some oversize rings for a 1938 Coventry eagle two stroke. Rang them and they were through my letterbox the next day!
