Rocker oil feed banjo bolt thread type/size
Hi all!
Would anyone happen to know the thread size/type for the rocker oil feed banjo bolt? I've managed to strip the thread in one of my Navi heads, so am considering a threaded insert.
Cheers,
Gez.
5/16" x 22 BSF.
Just made a (modified) couple for my navigator.
John
Hi John!
Thanks muchly for that: I've found a local place that'll supply and fit an insert for me: I did inserts in my apprenticeship too many years ago, but don't trust myself doing it in the soft head (assuming aluminium).
The bolt is the same size for Dommi & Commando. See below.
Plus, on the lightweights, the head steady fixing stud has the same thread where it screws into the head - a departure from the normal Whitworth thread used elsewhere on the bike, where a stud goes into aluminium.
Oil Feed Banjo Bolt
Thanks Andy.
All sorted now, thanks to my local, oldie worldie machine shop. If anyone down my way (Portsmouth area) needs this kind of assist, here they are: https://www.bandaengineering.net/
They did the threaded insert on the Navi and in the past have done a hone and rebore for my Bantam... All quickly and at reasonable prices.
