Hi all!
Would anyone happen to know the thread size/type for the rocker oil feed banjo bolt? I've managed to strip the thread in one of my Navi heads, so am considering a threaded insert.
Cheers,
Gez.
Screw thread size
oil feed banjo bolt
The bolt is the same size for Dommi & Commando. See below.
Plus, on the lightweights, the head steady fixing stud has the same thread where it screws into the head - a departure from the normal Whitworth thread used elsewhere on the bike, where a stud goes into aluminium.
Thanks Andy. All sorted now…
Thanks Andy.
All sorted now, thanks to my local, oldie worldie machine shop. If anyone down my way (Portsmouth area) needs this kind of assist, here they are: https://www.bandaengineering.net/
They did the threaded insert on the Navi and in the past have done a hone and rebore for my Bantam... All quickly and at reasonable prices.
Banjo bolts how tight? …
Banjo bolts how tight? Copper washers need to be quite tight to seal and on old threads?? you have the problem. Are there any alternatives?
GRAHAM
5/16" x 22 BSF.
Just made a (modified) couple for my navigator.
John
