So this saga goes on.
I decided to remove the inner gearbox cover and inspect the lay shaft and main shaft. Everything looked good so I tried reassembling but I am having trouble getting the extension on the selector fork into the cam plate.
I even tried partially removing the main shaft without success.
Is there a simple trick I cannot see?
Many thanks Roger
Camplate in neutral position…
Camplate in neutral position?.
