Here's a problem which challenges my intuitions about the laws of nature — and definitely contravenes Sod's Law:
Went for a ride (to test my new indicator set-up); crack the throttle open when I get to the by-pass; when I go to shut down the engine won't settle down to ticker but races at about 3000 rpm.
Initial perplexity is that I can't detect any abnormal slack at the twist grip. This goes away on further inspection, which reveals that the right-hand throttle stop screw is about 1½ turns too far in. However, the second perplexity is that I'm pretty sure that it was correctly adjusted before setting out.
So I readjust and ride home, and by the time I get there the same problem is starting to return. Another inspection reveals that the throttle screw has once again wound itself in.
This seems scarcely believable, but two further test rides produce the same result. It turns out that the O-ring is knackered (see photo). It's not easy to see in the picture, but the O-ring on the left-hand screw is nearly as bad as that on the right.
So it's not a mystery that the throttle screw has become self-adjusting, but how does it manage to screw itself in? Sod's Law suggest that it should unscrew and fall out, never to be seen again.
In the interim you could …
Murphy right again
Guess that the O-ring was incorporated in the design for a reason. When coming to age the O-ring and the thread in the carb and on the screw becomes worn. As the the throttle is at least partially open most of the time when riding, the screw is usually free to rotate. The pattern of vibrations tells if it will go in or out.
As Mikael says, it's the…
As Mikael says, it's the vibrations wot does it … I'd be very interested to hear any theories as to why the result in this case is screwing in, rather than screwing out in accordance with Sod's Law.
New parts are on order from Burlen; in the meantime some dabs of rubber solution applied to bridge the ends of the screws to the carb body have proved effective.
Hi Julian How old are the…
Hi Julian
How old are the carb bodies? Mine did that when they were hot because they were old. Maybe a little light emery papering may help smooth out any distortions in the bodies which could be making the slides stick when hot. Just a thought.
Chris
Chris, To the best of my…
Chris,
To the best of my knowledge the carbs are as old as the bike so, since it's a '72, nearly half a century !
But there's no sign of the slides sticking, hot or cold (they are Burlen's current hard-anodised type, btw) — the problem, bizarre as it seems to intuition, is definitely the throttle stop screw (it is mainly the r/h one) screwing itself in.
Working hypothesis
Executive summary: the air pressure differential between the two ends of the screw is the explanation.
It is clear that it is engine vibration which drives the screw’s movement, in the absence of the braking effect provided by the O-ring. The problem is
(A) why does this cyclical motion result in an overall trend in one direction, rather than a random walk around the original setting?
(B) why is the trend in the direction of screwing in, when Sod’s Law predicts screwing out and being lost?
In what follows, we assume for simplicity that the carburettor’s motion is strictly vertical, that the screw is vertical in the carburettor body, and that the effect of gravity can be neglected, and that the throttle is open and the slide not resting on the stop screws.
- The lower end of the screw is exposed to atmospheric pressure, while the upper end is exposed to the inlet tract which is necessarily at below atmospheric pressure. Thus there is a persistent net upward force on the screw when the engine is running (remember we are neglecting gravity).
- Now consider what happens when the carburettor is about to change direction at the upper limit of its oscillation. There is necessarily some clearance between the thread on the screw and that on the carburettor body. As the upward motion of the carburettor ceases, the momentum of the screw plus the net air pressure on the screw will tend to force the screw thread against the underside of the carb threads. Wedging of one thread against the other will tend to drive the screw to the right and thus turn it clockwise.
- At the other extreme of oscillation the screw’s momentum now forces its thread against upper side of the carb thread. However, in this case the atmospheric pressure now counteracts the momentum, so although the wedging action resulting from momentum will tend to turn the screw anti-clockwise the effect is smaller. Thus the net rotation of the screw will be clockwise.
While the net effect per cycle may be very small it can nonetheless quickly produce substantial visible effects. If a gentle test run involves an average engine speed of 2000 rpm, then a five-minute ride means 10,000 cycles. A net rotation of a tenth of a degree would be enough to generate three turns of the screw (in other words 1080º) which was the order of change that I was experiencing.
Experimental verification…
Experimental verification would seem to involve building a test rig that would oscillate the carb, with a facility to vary inlet tract pressures ± atmospheric. If runs with the inlet tract above atmospheric consistently unscrewed the throttle stop I'd take that as confirmation.
Lacking the time or facilities, however, I'm just waiting for Burlen to supply some new parts.
temporary fix
I suspect PTFE tape round the O ring would be enough to stabilise it if you were a long way from home. I have also started using same for some non-critical bolts ( kickstart clamping screw for example) as an extra security measure against vibration.
In the interim you could run a bit of lockwire thro the slot . My pillion footrest and silencer nearly fell off last week. Locktite !.
