A Dominator I am rebuilding came with rear shocks shown in the picture. At 70mm diameter they are too wide and foul the mudguard.
Dimensions are 11" x 2-3/4" shroud diameter.
Does anyone know what they come from?
Did the earlier bikes have…
As Alan said standard fit to…
As Alan said standard fit to the wideline bikes
These shocks aren't Jamports...
The "standard" shocks I bought are 2-1/4" diameter and fit perfectly.
These 2-3/4" items that came with the rebuild bits are too wide, they foul the mudguard.
I've been told they aren't Jampots, see photo of a Jampot attached.
Our local club doesn't know what they are.
Any ideas?
What year is your Dominator?
You don't mention which model year you have, but pre-1956 models had Armstrong rear shocks, which were a little larger in diameter than the later Girlings. They tended to have a chrome lower spring cover with a knurled ring, which yours do not have; but not all did.
Does it matter all that much? If they are wrong, they are wrong. Replacements are cheap enough, and work well in my experience. As such, s/h ones won't have much value, even if you do find what they were designed to fit.
Thank you Ian..
.. for your comments. It's a 1957 bike.
I'm trying to find out what they come from, so that I can let some owner somewhere (here in South Africa) have them. It is extremely expensive to import spares (R24 = 1P), and I don't want to simply throw them on the scrapheap.
Working on my 63 SS i find…
Working on my 63 SS i find the orriginal (very rusty) shocks still have all the rebound damping I can use . Good old brit engineering . Jap stuff of the day had useless damping when new .
Richard. Living in SA does…
Richard. Living in SA does put a different complexion on it! All the more reason why a previous owner fitted whatever he could get hold of, perhaps?
I have just measured a set of Armstrongs I have; not off a Norton; and the top shrouds are 2 1/2" diameter, so 1/4" shy of yours, which makes all the difference, obviously.
My guess is they are not off a British bike, possible off a European manufacturer, so you could have your work cut out identifying them.
Good luck!
Thank you all.
I'll try to find someone here in SA who will have a home for them.
Did the earlier bikes have more room ?.
