I noticed this question of the FB forum.
The gent asked if he should use 0 clearance on his 31 500 OHV Norton as the clearance increases when hot.
My 31 requires .002 In & .004 Exh
Is anyone else setting their early 30's OHV 's to Nil ?
Since seeing this question I haven't been out on my 31 to check if indeed the clearances do increase.
My Rudge runs zero inlet. I…
Valve clearances
Continue to use 0.002" for inlet and 0.005" for the exhaust. Post war singles have zero clearance with the pushrods free to rotate.
Thoughts on clearances
Specifically on singles:
I have always been told to set the clearances at zero on ohv singles, that is, just free to rotate when cold. It is my understanding that when going from cold to hot, the elongation of the cylinder (and head) will create the required clearances because the cylinder and head will expand more than the pushrods will, thus giving adequate clearance.
I know mineb gets a little…
I know mineb gets a little noisy when hot. This Saturday I'll be out for a ride. I'll check mine when the motor is good & Hot.I'm curious now.
I use the "free to turn…
I use the "free to turn pushrod" method on my 1961 ES2 with success. It is also way my 1960 Royal Enfield Bullet 500 is set, also with success. The factory service manuals for both bikes say to set them this way.
My Rudge runs zero inlet. I think that because the running conditions can vary so much its difficult to predict which parts are going to expand first ,so a little clearance is a safeguard in case the valve expands first and leaks with loss of compression and seat burning. Just a guess !!.
