Tank badge screws
Hi can anyone help with the size and length of the screws that hold the tank badges on
One reference I found says the following for a Jubilee:
pn 20230A Long
and
pn 20230B short
A further interchange I found said that 20230B interchanged with a Triumph pn210649
210649 is described as 4BAx1/4 If this is the short one, the longer one must be 5/16" or 3/8" long.
I couldn't find a listing for the Navigator. Your inquiry did not say what model you had
Good luck
Hello there,
It's been a long time since I fitted any tank badges but I think I actually used the brass screws which hold your ordinary household light switch onto it's wall box - I just cut them down to size to suit. Mike's information about a BA thread is almost cerainly the correct thread but from memory of a few years ago the electrical screws fitted easily even though they are probably a metric thread. They are worth a try and are readily available very cheaply but proceed with caution.
Patrick
