Sleeve gear bearing oil seal
Hi anyone fitted the seal with gearbox in situ if so any problems to overcome thanks Eddie Bellamy
hello eddie yes its easy ?
thanks for the reply Anna
thanks for the reply Anna well you need too remove your inner and outer primary chain-case's yes that meet's removing the clutch as well then undo you chain too the rear wheel
then you need too remove the sprocket the big nut that holds it on is ant-clock-wise left hand thread then you can get at your oil seal there's steel on the out side the rubber is on the inside you need suitable tools too remove it , so have fun get stuck in ?
Hi Anna did what you suggested no problems and now no oil leak so thanks again.
