Persistent excessive wet sumping
OK chaps, hereâs one for you.
850 MK2a Commando which will empty itâs oil tank into the sump over night, cold engine & 20/50 oil, everything apparently in perfect condition.
Let me give you a little history.
The bike belongs to a friend, heâs owned it for years & has always had this problem. Iâve been involved in a lend a hand/shoulder to cry on capacity & weâve tried/checked all the usual suspects, including fitting new oil pump & all gaskets/seals etc over the years, all to no avail. The engine ran well & was lovely & quiet with no unusual noises, however, the bottom end was taken down for a look but nothing untoward was found, so was put back together with new shells etc. He then decided to fit an anti drain valve from one of the well known suppliers, which did indeed stop the wet sumping. Unfortunately less than 500 miles after fitting, both big ends nipped up, bending the rods & wrecking their journals. The engine is now back together with a replacement crank, new rods, bearings, cam, another new oil pump etc & still empties the contents of itâs oil tank in less than 24 hours. The crank cases & timing cover are the only original major parts left of the bottom end of the engine but look to be in perfect condition with no cracks or damage evident, very lucky considering the above, fortunately when it nipped, he had just ridden into his garage after a ride, heard the death rattle & was just about to kill the engine.
Could there be some porosity in the cases which lets the oil drain? Has anyone come across this before? It may explain why the big ends were starved of oil with the anti drain valve fitted, if the pump was able to suck air through the porosity instead of being supplied oil by gravity?
Not surprisingly, heâs not keen to refit the anti drain valve & has lived with this problem for about 20 years, so will continue to do so if he has to, but it is a pain having to drain the sump every time he wants to go for a ride, so would like to find an answer if there is one.
Any ideas ?
Regards, Tim
Tim,
I have 2 x mk 111 bikes, one of which wet sumps (after a couple of weeks ) the other one takes months to do it, so no problem.
Anyway, after going through as much as I could think to do to stop it , I eventually fitted a plumbers gas tap to the feed line, and when the bike is not being used regularly I switch the oil off. I didn't want to fit an anti drain valve (though I have an LPW version on my Trident, which works fine)
Of couse, I know that one lapse in concentration and it's a blown motor, but it hasn't happened since I fitted it, and I do have a reminder stuck on the tacho.
I believe some owners fit the same type of thing but with a micro switch fitted that disables the ignition till the oil is switched on, but to me that's just something else to go wrong.
I realise that this is masking the actual problem, but I'd rather ride the thing without having to drain the sump every time I use the bike.
sam
Hi.
Check that the brass end plate on the pump doesn't protrude beyond the mating face (against the crankcase). This wouldresult inthe symptoms you describe. Put a steel rule across the mating face of the assembled pump and hold it up to the light to check. My Dommi's did!
Regards,
Ian.
Some models of the Mk 111s have an anti-drain valve built into the timing cases. Must be something missing if they still wet-sump!!!
Back to Tim's bike. My money is going on some crankcase distortion in the region of the oil pump. This problem came to light on the 750 Commando in 1971 and consequently the fitting of a paper gasket to the face of the pump became the norm from then on.
However, do check that all the mating parts are seriously flat. I've seen oil pumps, straight from the factory, that had ground faceslooking more like the top of of an old gramophone record. You could trim finger nails on the very poorly ground mating face. Also, check out where the studs go into the crankcase. If these have been overtightened at sometime, then they will pull up a ring of alloy which will hold the pump away from its respective mating surface. A similar problem occurs on the cylinder head with rocker cover studs getting the 'heavy-hand' treatment.
My Mk 3 used to empty its entire oil tank contentsafterabout two weeks ofstanding despite the Norton standard Mk 3 anti-drain valve beingfitted, both before and after a complete rebuild ,so finally fitted a Mick Hemmings anti-drain valve - cured the problem and so far so good.
With the stories of engine blow ups from some who've fitted various types of after market anti-wet sumpingdevices , I just wonder if anyone has had this experience with the Mick Hemmingsvalve ? It's well made and based on the Velocette anti-drain valve which was fitted as standard on their bikes.
Obtusely my '73 Mk 1Ahardly loses a drop from theoil tank afterthree months of standingso doesn't needan anti-drain valve - go figure !
Thanks for the replies gents,
Sam, I have a tap fitted in my model 19, it was there when I bought the bike & I do use it when the bike stands for a while but my friend is not so keen, heâs not convinced heâll always remember, but thanks for the suggestion. (I always remove the plug lead & hang it over the tap as a reminder)
Ian, Iâm reasonably sure the pumps were checked for that sort of thing, certainly the two that were removed are OK, one is now in one of my Commando's & the other is in my spares cupboard, I checked that last night & found the brass plate to be lower than the cast body & this problem has endured over 3 pumps & 2 bottom end rebuilds but again, thanks for your input.
Phil, I always slightly countersink threaded holes in such areas, as have come across this problem lots of times myself (particularly on the front two studs that drop down from the head through the barrels & take the sleeve nuts, often the cause of oil leaks in that area.) & did this to my friendâs cases while checking them over for him after the seizure although they werenât really bad to start with. (Despite being a qualified light aircraft fitter, heâs had me double check everything just to make sure heâs not missed something) Mating surfaces were all checked for flatness etc & deemed to be fine, the original pumps mating face was indeed like a coarse file, but the two replacements were/are nicely machined. I had heard/read about problems in this area in the past, so this was looked at early on. Iâm wondering if we can remove the timing cover, plug any oil ways to/from pressure relief etc &, given the speed with which it drains, see if we can observe where the oil is going? It ought to be fairly obvious if itâs leaking through the pump or between pump & case which would confirm your theory but my concern is that there is a hidden crack or porosity in the feed to the pump which, when having to overcome the restriction of an anti drain valve, allows the pump to suck air instead. Thanks for your suggestions.
James, I did suggest that maybe he could substitute the original timing cover for a MK3 item but I hear of so many MK3âs that suffer as much wet sumping as any other models, I wonder if it would be worthwhile, especially if the problem is before the pump.
Iâm fairly sure the anti drain valve was an M/H one, most of his Norton shopping is done at Mick Hemmings or Andover Norton, Iâll try to confirm that, but thatâs not to say anything against the valve, there would seem to be many in use successfully, & as I say, I think the problem probably lies in the supply line to the pump.
My bikes all vary in the time they take to wet sump, with no obvious reason as to why one does it quicker than another, but none of them will empty their tank overnight like my friends does.
Incidentally, I had a Venom with itâs standard anti drain valve & despite many attempts, I could never get it to work consistently, sometimes the ball would seat nicely & the oil would stay in the tank indefinitely & sometimes it obviously didnât seat correctly & the oil would drain quite quickly. Talking to other Vello owners at the time, that didnât seem uncommon. Once again, Thanks.
Regards, Tim
I have just fitted a Mick Hemmings anti drain valve to my 1970 Fastback. Before that it would take about a week to drain half a tank into the crankcases. I was suprised at how much I had to suck on the valve to open it, I was thinking it would have been a lot lighter spring. In addition I thought the bore of the exit pipe would have been a bit bigger as well, as there is scope to have a larger diameter exit tube and still fit 3/8" dia rubber pipe. I know Les Emery will not touch anti drain valves but then I ride my bikes most days.
Hi All. Now that has raised an interesting point. i was today just about to order the MH Anti Drain Valve (TX1474) But after reading all your thoughts i may, for the short term, stick to draining the 1 litre per two weeks from my 72 750 Commando. Its not that its an effort but i do worry about the thread in the crank case.
Mark.
If you fit the sump plug with the built in drain plug you wont have to worry about the threads.
Mark,
Please don't let my comments put you off, as I said, there does seem to be many happy customers & the Commando in question would appear to have an under lying problem that MAY have been exacerbated by the fitment of the valve.
Robert,
Unfortunately 1972 on 750 Commando's dont have the large sump filter of the earlier & 850 models, they just have a small magnetic drain plug.
Regards, Tim
Idont know if my 850 mk2a wet sumps or not as i dont give it chance to.I fitted a valve made by john epp in canada (look on access norton website) it is a manual valve but has a plunger type electrical switch fitted to it. This i have wired from kill switch through the valve switch to work a relay (fused relay operates boyer straight from battery for best voltage) so if oil is not on no sparks. If you forget to turn oil on you soon remember or its you that gets hot an stops turning things over not the engine. In back of some classic bike mags (and I thing the AJS owners club mag maybe) someone advertises an English made valve with the same idea from time to time or you may be able to make something of your own design along those lines. Mine did cost about £100 which is not cheap i admit but is well made neat and easy to use but above all alot cheaper than rebuilding an engine if you forget or if automatic valve fails an stop closed also some say that the auto valve may restrict flow to the pump (depending on type) an so strave engine at high revs when oil flow is needed most.
I know this in your case is not solving the problem but as you say all that is left is the cases of your original motor so fitting such a valve would be easier and cheaper than new cases or a complete different motor. Good luck with it Karl
Obviously, there has to be a reason for Norton wet sumping, the gear oil pump is susceptible and common across the board. But why some worse than others in the standard set up? My 76Mk 3 will empty it'soil tank in about 4 weeks when left standing if I leave it on compression. About a week sooner if I don't.
On the other hand, I have a 1960ES2engine that will empty it's tank in two weeks but a 1959 model 50 enginethat does notwet sump at all, not even whenleft standing for the best part of a year. Why?
All oil is straight 40 with light detergent in the Commando.
As for wet sumping over night, without finding the cause I can only think of two courses of action. First is the tap of one kind or another, the other is to leave the sump plug offwhen left overnight with a container under it. Not much fun if you are away from home though.
Please let us know the cure if you find what was causingthe problem. (Looks like the cases?)
Gentlemen,
I fitted a M / H anti drain valve to my MkIIA three years ago with no issues post installation. Previously, the bike would deposit the contents of the tank in a couple of weeks, despite refurbishing oil pump etc. However, this happening overnight is extreme and suggest another problem. If it was mine and, after the exhaustive diagnoses performed by others, if nothing cane to light, I would fit a manual tap and a "Remove before flight" lanyard and hook is over the bars or somewhere appropriate!
Good luck!
Rgds Steve
Hi Robert. I have seen those, but they list for engine numbers before 200000 and after 300000. and mine being a combat engine falls in the middle catagory, but i will ask. Thank you. Mark.
I am not against anti-drain valves asseveral bikes did have them fitted as standard. But I have a huge concern, in the case of Tim's bike, if such a device is fitted without first discovering the root cause of the wet-sumping problem.
If his engine is dumping such a large amount of oil into the sump then it is still likely to do so below any fitted anti-drain valve and therefore leave air in the system. If the main problem is caused by a gap or hole anywhere in the feed plumbing then, when the engine is started, it is going to suck on air possibly to the extent that the AD valve does not release.
This is a problem encountered in the past, by other Norton owners,often as a result of poor fitting of the AD valve. Reusing the oldoil tubing was the most common mistake.This hadgone rigid andno longer madea good seal in the system.
Tim........ another possible way that oil canbypass the pump in such quantities is if there is a fault in the feed tunnel. Perhaps during manufactureof the cases.Check out the attachment.
The GREEN arrow shows the feed in and the RED up from the sump. They would meet at the BLUE star if the drilling of the oilways was done a bit carelessly. Oil from the tank would then bypass the pump and go straight down to the sump. You could check out any problems in this area by removing the grub screw on the outside of the cases (at the base ofthe RED arrow), push inside some tubing (todivert any oil going down to the sump)and seeing if any significant amount of oil drips out.
photos-351-jpg
Hi Tim,
As it dumps the oil so quickly have you considered removing the pump and fitting a bit of tape or similar over the feed holes and then replace the pump. Fill the bike with oil and leave overnight. If any oil has drained into the sump then the problem is before the pump. If none has drained then it is the pump or after.
You may be able to do a similar trick with the exit from the pump where it feeds to the crankshaft.
Break the pronlem down into sections and it may all become clear.
Best of luck.
I'll second that, process of elimination. Dumping that much oil over night is a real problem and on second thoughts, fitting a tap is not the answer. Please keep us posted.
Hello chaps,
Phil, youâre thinking along the same lines as me, I was thinking crack or porosity but must confess I hadnât thought of faulty or incorrect oil way drillings, thatâs a big possibility, thanks for that, I will investigate further in that area as we certainly couldnât see anything obvious when we had it apart.
Tony, Yes, I was thinking of removing the timing cover & observing where the oil is coming from/going to. Iâve sort of ruled the pump out as weâre now on pump number 3, number 2 is now on my yellow Interstate with no problems, & to be honest, I think if a pump let oil through that quickly, it probably wouldnât pump anything round the engine, but still worth blanking it off to see what happens, itâs beginning to look more like a problem in the crankcase.
Weâre both tied up this weekend setting up for our local Fenman Classic bike show on Monday, doubly busy for me, as I help set up the Norfolk branch stand etc & am also on the show committee, but we have decided to try to get to the bottom of this as soon as we have a few evenings spare so any other ideas/suggestions are welcome & Iâll report back with anything we find. All this has made me wonder if maybe we may have stumbled onto the reason some MK3âs still wet sump quite badly despite their anti drain valve? Maybe the oil drains before it gets to the valve?
Regards, Tim
Any ideas ?
Regards, Tim
My 1971 Fastback also wet sumps if left for more than 2 weeks between rides. Norton always claimed that their engines didn't do this, but my engine was rebuilt by Norvil with a new pump and all new bearings etc. It still does it even using straight 50 as recommended by Norvil, and leaving it on compression. There are no other symptoms, the engine runs well andoil returns to oil tank fine. I am not in favour of fitting anything in the oil supply line which restricts the flow in any way. I have fitted the sump plug with the central drain, and use this if the bike has been left standing. I would suggest the "problem" arises mainly through lack of use, if my bike is used regularly, it doesn't do it.
Hi
I have the same problem of wet sumping on my Domi have read about most of the comments that have been mentioned here before but have not read that it could be the seal from the pump to the timing cover as this is hard to determine. Has anyone been down this path ? I think I will go for the tap with a switch as a safe option. As I bought my domi with a blown engine from the tap being turned off!! As a now old codger do not trust my memory.
Nick
Nick
Ditto. I have three wet-sumping Nortons, in all of which I have installed taps in the oill feed lines. On one the tap also switches the electrickery on/off, on another (which has an ignition key) the key resides in the hollowed-out underside of the tap until needed for its primary function and on the third, a magneto-powered specimen, a dayglo disc lock reminder cable loops round the kickstart lever and the off-position tap. Works for me.
Well All Norton twins lubrication is to the main bearing journals , and low presser feed to the rocker arms every thing Else in a Norton twin motor is splash feed So fitting a tap or other devices will only mask the real problem the old pump, if you have renewed the oil pump We can rule this one out, so the best way of finding a crack or porous alloy ,Is to empty the oil tank, and remove sump plug drain every thing off, clean the sump plug ,replace the sump plug , them mix up some Engineers Blue with spirit and clean engine oil now fill the tank to one 1/4 and leave over night then drain it all off , take off the timing cover and you see the blue stain were the oil mix has been this is how we did things on the Ships, hope this helps yours Anna J
Anna is 100% correct regarding a tap or valve in the oil feed line masking the real cause of wet-sumping. In Tim's case, I believe he has an issue behind the oil pump on his bike. ie porous metal or a crack.
As a rule of thumb, in all the yearsI have been helping to sort out wet-sumping problems, theroot cause has often turned out to be a worn or damagedoil pump. This is the first line of defence against the contents of the oil tankheading for the sump.
The next weakness in the system is the oil seal in the timing cover. Like the main crankshaft oil seal, this is often re-used time and time again with scant regard to its condition. Careless refitting of the cover or any debrisfrom oil tank will quickly kill off thesealing effectiveness of this item. Commando owners will tell you that if extreme care is not taken with the points oil seal, on their bikes, then they get an instant pressure feed to the points. There have been some cheap versions of these seals on the market, for a few years, and they are absolute rubbish. They distort in use and really should be replaced each time the cover is disturbed. Stick to a big name supplier.
Logically, if the oil is escaping, at great speed,from the system when the engine is not running then it is likely to do so even faster when the motor is being used. In which case....how long will those big-ends last???
Hello all,
Unfortunately Stephen, lack of regular use is not the problem in this case, if you rode it to work this morning, you would find that by the time you wanted to go home, most of the oil would be in the sump. Youâd have to take it for a run at lunchtime to have any chance of still having oil in the tank at home time. Whilst being a good excuse for more riding, itâs not terribly practical.
After some more investigation over the last few days it looks like the oil is draining directly to the sump via the return drillings, so looks like Phil gets the points here. I removed the large sump filter & plugged the drilling that would normally take oil from the sump to the return side of the pump, left a drain can under the bike & left it overnight. Next morning, there was about a tablespoon of oil in the drain can & the oil tank was still full. After three days (&nights) we now have about half an average coffee mug of oil in the drain can so looks like there is very little seeping through the pump or anywhere else. (Without the drilling plugged, oil drips out at an alarming rate.) Next step is to try to ascertain exactly what the problem is, i.e. bad drilling. Faulty casting etc, & see what can be done to rectify it. Iâm thinking if we can clean it all out thoroughly, inject some epoxy resin or similar & then re-drill the oil ways correctly, that may do the trick, but it will almost certainly mean dismantling the engine again, so something for the winter, for now, heâs going to continue draining the sump & enjoying the remaining good weather.
Once again, thanks for all the suggestions, Iâll report back with what we discover & what we are able to do to rectify as & when we get that far.
Best regards, Tim
Hi all , My 750 Fastback wet sumps over about two weeks . I fitted an anti drain valve ,( BRI TIE ) but to ensure i could monitor its performance i also fitted an oil gauge which i mounted in an aluminium pod between the Tacho /Speedo . I have run this way for over ten years and had no problems.! On starting the bike i can see the oil pressure build up and know the valve has opened . I also was supprised at the strength of the valve spring when testing it prior to fitting . I recently purchased another valve for my Moto Guzzi Lodola which i have yet to fit . Its an aluminium assembly machined from bar stock , and can be stripped for cleaning . The spring in this is much lighter than the Commando one ,but the seller assured me it is highly effective in use and can be mounted in any position .vis vertical or horrizontal. I have yet to try it . Any one interested , its currently on FleeBay, from a chap in Northallerton , North Yorkshire At £19.95. + £2.5 post.
More lateral thinking..................On most standard Dominators, the return feed, from the pump,goes into the bottom of the oil tank.Oil then has to passthrough some internaltubing to the top of the tankbefore adding to the contents. A split in this tubing would giveoil from the tank a quick route back to the sump via the return gears of the pump, which always wear more than the feed side.
On my Commando the return pipe goes, externally, straight to the top of the oil tank. Does yours???
I've just come back to this thread and before I got to the bottom/last post from Phil, I was thinking that the return pipe through the oil tank must be cracked or perforated to allow the oil from the tank back into the cases. If you were to connect a pipe to the bottom of the oil tank return and blow on it after blocking the outlet with your finger, you should not expect to see any bubbles.
Tim, don't be shy, please tell us which well known supplier we have to avoid when buying our non return valves. Then others will benefit from your bad experience.
Be careful paying too much attention to AJD's opinion as according to her post , the main bearings are pressure fed.
Hello chaps,
Return pipe is external, so not the cause in this case, it certainly looks like the problem is in the crank case's, oil appears to be able to enter via the feed side & exit via the return WITHOUT going through the pump !, We've tried Tonys idea of blanking the pump completely & the oil still runs straight through. Will investigate further over winter when the bike is in hibernation & see what can be done.
David, the anti drain valve was a Mick Hemmings item, but I have to stress that I think it only amplified the existing problem, ie the pump is able to suck air if the oil feed is restricted in any way, this should not be the case if everything else was as it should be. I would highly recomend anyone thinking of fitting an anti drain valve to check very carefully for any similar problems to those described in this thread before they go ahead, once satisfied there are no other issues, then I see no problem with fitting the valve.
I kind of hoped Anna's post was a slip of the virtual pen, so to speak, but would also have to point out that later Dommies & all Commando's do actually have high pressure feed to the rocker arms. I often think this is where some confusion starts, some seem to think a Norton twin is a Norton twin, whereas in truth there are a raft of differences between the earliest & the latest & they should be treated completely differntly.
Regards, Tim
The website encountered an unexpected error. Please try again later.
