Hi can anyone help went out on the navigator on Sunday and am getting an oil leak from the gearbox drive sprocket .I have ordered up a sleeve gear oilseal .On strippin the primary case off of the engineI find there is an oil seal that seems to be rivited to the casing does any one know if this is a spare part from the club and do you nhave to drill the fivets out .
Thanks Steve
Hi Steve, According to the…
Steve, After you Clutch Tr…
Steve,
After you Clutch Trouble - I've picked this one up too! The seal on the "other side" of the G/Box mainshaft - leading thru to the clutch is behind the Drive side housing (Clutch Casing) held in by 3 rivits thru a flimsy retaining cup and opposite the G/box Sleeve Gear Bearing Oil Seal (part no 041247 - I think - the one I believe you've ordered).
I think the Part Nos you require are - Chaincase Oil seal - 22474, and its Retaining Cup 20993 - available thru NOC Spares (I think!). The Rivits need to be GENTLY tapped out by hammer (supporting the chaincase) or LIGHTLY drilled and then tapped out... standard rivits will need to be separately acquired.
In general though - this seal only retains the "splash" oil held in the Primary Chaincase - even though I replaced mine some time ago - it still dribbles a little - keeps the chain lubricated - if your Sleeve gear bearing oil seal is weeping - this will certainly deliver more oil onto the G/Box Drive sprocket "chamber" - but then - see my other comments - as you will be stripping the primary (Drive Side) Clutch / Casings etc off - why not replace this Chaincase Oil Seal at the same time ? By the way - keep the G/Box oil level UP to approx 2.5 pints (1.25 litres) - thats another MUST... (and another story if you don't).
Enjoy and Have fun!
Brian
Whoops [typo problems] tha…
Whoops [typo problems] that's 4 rivets (not 3) that hold the retaining cup (20993) & seal (22474) to the back of the Primary Chaincase that need to be gently puched out...
Brian
Previously brian_ascough w…
Previously brian_ascough wrote:
Steve,
Enjoy and Have fun!
Brian
Thanks for the information am still waiting for the oil seal but have just noticed the spacer for the sprocket has a shoulder on the outside diameter does the spacer go on first with the shoulder on the inside then the oil seal or do i push the oil seal in then have the shoulder on the outside my own fault for not noting when i pulled the seal out The manual showes no 78 but i can not see the shoulder
Thanks Steve
Hi Steve, Now this one you…
Hi Steve,
Now this one you've got me on! I do know there is a "distance piece" or spacer for the sprocket (No 78 on diagram), but not having stripped the box out for a good while - I'm afraid I cannot remember..... I think the spacer run in the seal (?). Sorry - best I can do for now
Brian
Hi Steve,
According to the Jubilee spare parts list (1959) the oil seal, retaining cup, and rivets are listed as spares. I don't know if the NOCshop keeps the oil seal as I have not changed this item recently as strangely enough this seal doesn't seem to leak too badly . Well you know what I mean - there's bigger leaks everywhere else as a rule and the sleeve gear one is the usual culprit in this area.
if you get in touch with Ian at Spares he should be able to say for certain as sometimes items are in stock but not listed on the website. His number and email are in Roadholder and he is easier t contact than Neil.
Patrick
