Is there a difference between Single, Dominator and Commando oil pumps, besides the drive gear? Could I use a Commando oil pump in an early Dommie 88?
The part numbers from my p…
The later pump would flow…
The later pump would flow more oil and that can give problems. Might work with the orriginal 3 start gears. Extra flow could give problems with mag as the pressure relief valve works harder.
Later pumps flow more due…
Later pumps flow more due to having wider gears on the feed side as well as six start worm drive as i understand it. This may or may not affect the overall width of the pump i am not sure but its worth finding out. The mk3 Commando pump has a different seal boss on the outlet to the earlier type also for a wider seal that is used which would need to be changed.
Single-cylinder pumps are…
Single-cylinder pumps are 'handed' differently. You can completely ignore them from the point of view of usage in twins.
This photo shows l to r - Mk3 Commando, Earlier Commando and Single.
Current Andover production of oil pumps is of very good quality.
oil-pumps-2-jpg
Thanks for that, Richard.…
Now I know what to look for at jumbles, not wanting to pull the cover.
Previously richard_payne w…
Thanks very much for the p…
Thanks very much for the photos, Richard. There are big differences and one can easily see the difference in the drive gears. I will check out Andover.
The part numbers from my parts listing for 1961-1962 models are as follows:
for 88-99 pn 15522
for 650 pn 23111
for all singles pn 15521
What the differences are between the models, I do not know.
I would guess that the necessary flow rate for the twins would be greater than for the singles.
