Norton 16h Dollhead Gearbox
Hello,
I'm looking for the good way to disassemble the clutch worm nut on the Dollhead gearbox as i want to change the feltwasher inside.
Did you guys have a good one? As i dont want to destroy the brass.
Regards,
I think your trying to release the outer cap from the brass body to get the felt  replaced.  Brass body steel cap  can be a little difficult to part. The oil cooking into the threads and  seizing.  I would  try a night in the freezer , then grip the thread in soft jaws and apply some gentle heat to the cap.  The nut is 3/4” Whitworth, or 33mm if you don’t have one.  Once it frees it usually spins off.
Be careful with the old felt, oil soaked inside too much heat and it could set alight.  A couple of cycles like this should work eventually without damage to the brass.  As David says the worm should wind out easily enough once you release the lever.
Jon.
… it may be worth putting it back into the casing after a few heat cycles and tightening the cap. It may just crack the grip then undo it as normal….  Don’t go nuts and damage the casing…
it’s an old trick a cabinet maker shared with me for rusted in wood screws.
Forget the felt oil seal as it is laughingly called. I fitted a 1/2 inch bore double lipped oil seal which fits perfectly in the chromed cover. You can fit first with a dab of oil on the shaft, clean the inside of the cover nut add a little epoxy resin to the face of the seal or inside the cover and screw into place. No more weeping or drips.
 1/2
Worth a try; as you say the felt only soaks up the oil to deposit it over a longer period.
