Mk.lll not charging
Hi all
Iâm not getting any charge to my battery, Iâve tested the alternator for continuity, ok and also rigged a bulb to the alternator wires which glowed brightly when I blipped the throttle, there is another test where you rig a 10amp meter on the output side of the rectifier
This is where Iâm getting confused as there are two rectifiers present one of circular discs and the other is a square solid state item, the solid state one I canât find in either the wiring diagram or the 850mk 3 parts book, if this is correct which wire from which unit would be the output
Iâm toying with the idea of fitting a modern rectifier/regulator unit and removing the zeners and rectifiers, what system should I be looking for and would I require a power module or a powerbox(podtronics) or both
My mk3 currently has the starter stripped out and pazon surefire electronic ignition
Thanks for any advice
I'm sure you should only have one rectifier. I've had a Podtronics regulator/rectifier fitted for the last 7 years/43,500 miles and no problems. My charging system compromises of alternator stator, rotor, podtronics and battery. Rotor has recently been replaced after magnets coming loose from hub, but it had done 143,500 miles. Upgrading to modern electronics makes sense in my opinion,
Simon.
Simon, slightly off topic but I'd be interested if you could write about your Commando experiences, what gives up at what mileage, what goes wrong and what works better etc. My Mk3 at 30,500 miles is only a baby to yours. Not enough high mileage features and yet these you learn most from.
Back on topic; on my sick 650, no charging was down to a bad connection from one of the two wires that come from the stator, at the connector, further up. Just a thought.
Simon,
You would expect a Mk.lll to have a 3-phase alternator setup. Two standard bridge rectifiers is definitely not correct. It's possible the original finned one went faulty, the previous owner fitted a more modern potted type and just left the old one in there.
Are both connected?How many connections are there to the square one?You are suggesting there are 2 Zener diodes - correct?
Chris,
That's what I thought re two rectifiers. I don't know about your other questions as it's not my bike - apologies if the second paragraph is addressed to Steve.
Neil,
I'll see if I can remember whats needed replacement and why over the miles,
Simon.
hi all
I'm sorry folks for stating I thought I had two rectifiers installed , (early grey moment)when I removed the battery to see what was behind it in the dark grotty bit near the blue u2 battery thing in the spring . I noticed sometime in the past the rectifier was upgraded to a solid state item
anyway it still not charging, the continuity from the alternator to both feed wires of the rectifier is good , I'm thinking a rectifier replacement may be in order ( cheapest option),
sorry for misleading you earlier
steve
Previously steve_elston wrote:
hi all
steve
Steve, that blue thing is the capacitor, if it is working it will give you charge to kick start with a flat battery. (Not if your charging system isn't working) A Boyer power box might offer a solution if the problem is not with your stator, rotor or wiring. This would replace the other bits that might have seen better days.
Previously simon_ratcliff wrote:
Chris,
Neil,
Simon.
Should be a good story Simon, I'm still on standard bore. Cams shot at 24K,Primary chain at 30K and a few bits in between on mine. Making the Amal Mk 1single carb conversion earlier would have paid for some of that!
Just purchased and fitted a A Reg One regulator / rectifier from Norbsa, I think Al Oz sells them as well. They are rated at 200W and easy to fit being smaller than the podtronics unit, It is also a lot cheaper. If need be I can supply photos of it fitted.
Not done many real miles on it to comment on the reliability, but in the Electrical section a lot of owners rate it.
The output wire from the regulator is the one that has continuity back to the battery negative terminal wire. The colours in the MKIII wiring diagram, though they correspond to the key, their use in the loom may not be correct depending on where your MKIII was delievred to or due to be delivered to. If it is US or UK it will be fine, Canadian 'lights always on' is different like mine.
Hope this helps.
Hi Ashley
Thank you for your replies today most helpful,and its nice to know at least some members take the time to read and understand others problems and not just hi-jack a thread so they can go off on a totally unrelated mileage topic.
I got to the bottom of the problem today,I initially changed the rectifier via maplins for 2.49p and got no improvement, as the stator had cooked itself.it would power a bulb,but do little else ( only 19000 miles not to worry anyone), New 200watt stator and rectifier/regulator purchased from e-bay,I'll post a photo or two of the stator.
steve
imag0836-jpg
You should check out why the stator has ended up in that state(or) (another joke) before fitting the new one.
Some members do seem to be getting a bit possessive about the content of threads sticking to the original posting, it's just the normal way conversations develop. I only included the mileage figure to give you an indication of the podtronics reliability if you were to buy one. The rotor mileage is also relevant to the subject of charging systems reliability - chill out.
The stator on the MKIII is right pain to install if it is new. It will helps to ensure that the primary inner cover is assembled correctly and tightened iaw the manual.
You may find that the stator / rotor clearance gap will be a minimum at the 1 O'clock position. Mine needed some fettling of the stator mounting holes with a round file to enable the gap to be obtained in that position. once achieved, the stator is always mounted in this position and in future will not be problem in future assembl, just check it. There is reference somewhere that the assembly can be tapped to get the clearance, but the idea of tapping the stator and alloy mounting assembly and associated studs is asking for damage. If I was mounting a new stator, I would order two primary chaincase gaskets so I could re-check the clearance once the bike has moved of the centre stand and has some power put through the primary drive, a pain I know, but cheaper than a new stator and the hindrance of breakdown.
I beleive that there is now a new stator and rotor that will give more clearance. Paul at Norbsa may know, as this as where I think read about it.
Where there is insufficient clearance (should be 0.008") I think it is best to file iron segments of stator where req. sounds brutal but works. Alternative is to turn eccentric dowels to suit either stator mountings on carrier plate or crankcase studs. Requires further machining to stator and/or carrier to fit dowels and allow required movement to establish stator is concentric to rotor. Problem is stator is sometimes not mounted concentrically to rotor so fitting rotor and stator with larger gap only masks the issue. I agree with Ashley, don't hit the assembly to try and achieve the necessary gap, or, as mentioned in Commando service notes, 'adjust' the inner chaincase central supporting nut.
The website encountered an unexpected error. Please try again later.
