Mk3 Camplate Neutral Button
I have bought a new camplate neutral button, as mine has quite a deep groove in it. As it is basically like a solid rivet, I carefully drilled into the deformed end of the stem and drifted it out easily enough.  However, the new one is not a close fit in the hole so will need a good whack with a suitably shaped punch to deform enough to grip, while supporting the button and avoiding damaging it.  The original seems pretty soft material, I guess to enable it to deform, which would explain the groove, so it needs to be properly supported.  I currently do not have anything to act as a dolly to support the button - has anyone else been in this position and what was the solution?  Andy
Make a tool that somewhat resembles a rivet snap, Drill a suitable shallow hole just under the full diameter of the button in a scrap piece of steel, then grind the drill just used into a round ended drill bit and drill the hole again to make a 'rivet snap' This will support the button when riveting it in the cam plate.
Thanks for the advice Peter.  However, grinding drill bits is not something I have attempted before and could be messy!  I wondered whether I could use a ball grinding stone to create the required button support, but have not so far been able to confirm the diameter required - I am estimating around 16 mm.  The original button width is 10.6 mm, whereas the A-N item is 12.5 mm.  Most grinding ball suppliers are in China; the very few UK suppliers I have found are pretty expensive, and often have delivery times suggesting they are also sourcing from China. So buying a selection is not realistic.  How typical that a procedure that is actually so simple and quick with the right tools is preventing gearbox assembly.  Might be simpler to buy a new camplate if available without the expensive spindle.
Asked RGM or Norvil what they would charge to do this for you? Or other Norton specialists? Maybe  our own Peter Shand could do it for you?
Might be quicker/simpler and know it has been done right?
Just thinking...
George.
Thanks for the suggestion, George, but I am loathe to send away and pay someone to fit something so simple for the sake of a suitable button support.  I will just have to use my imagination and find a way round this latest in a long line of hurdles - familiar territory for many, I guess.
It does not help that the good decent engineering supplies shops seem to be a thing of the past and online shopping is often so limited.
I may have a 1/2 inch ball ended milling cutter, need to check my collection tomorrow. If so I can create a depression for the button in a piece of scrap steel. You can mount that in a vice and apply force on the other side of the campsite to spread the other end of the button.
Found the cutter, 1/2 round ended so PM me.
John, thank you for the offer to make up a button ‘receptacle’.  I don’t know if you found a burr, but the new button, being 12,5mm wide with a shallow radius - button depth is only 3,15 mm - means a 1/2” ball would likely create too tight a radius.  It might make a good starting point to open out a little though, as long as it is no more than 3,15 mm deep. Depends whether you found a burr.  There seem to be lots for sale; just in much smaller sizes.
Andy
It's a carbide cutter, 1/4 steel shaft with 2 carbide circular shaped teeth. I have a 3/4 burr which would give a larger hole at 3.15 depth, plus if I mount the steel plate in my rotating table with burr offset from the centre it would be closer still.
Alternatively just drill a 10mm hole in scrap plate, you will end up with a 10mm witness mark but it should still work.
Be careful when 'riveting' button in the cam that you don't disturb the camplate on its spindle.
I had to sort out a clients gearbox that wouldn't engage any gears and after taking almost all the internals out i found the problem. He had screwed a new neutral switch in far too far and had then trod on the gear lever forcing it into a gear. This pushed the camplate out of kilter with its spindle, hence then no gears.
You could be over thinking this. When I fitted a new button recently, I just drilled into a piece of scrap steel to create a support. Although it was obviously not spherical, it supported the button just fine while I riveted the other end over with the ball end of a hammer.
Best wishes, Al.
