Lucas 318346
Anyone know where I can get the PRS8 switch knob and screw?
You will also require the small rubber unit that goes into the switch, where the key inserts.
If the switch is well used/abused then the thin metal construction inside the 'small rubber unit' that holds the correct key in place will be well 'mullered' so a new on of them as well.
While talking about the PRS (see my web site for its servicing) The screw that holds the knob on-when Lucas made this they inserted a (6BA) screw down the centre of the knob retention screw to spread it out and stop the knob rattling. All subsequent screws have NOT had this inner screw.
