Holed piston mystery!
PlugI know how everyone likes to look at other peoples problems so here's mine! On a recent road trip I was doing about 60mph up a gentle incline after leaving home 20 minutes before, the bike suffered a brief loss of power - then nothing - I coasted to a halt on the A30 dual carriageway. Not wanting to stay so close to 70mph traffic I pushed the bike 309yds up the hill to a layby. I should add that 6 bikes passed while I was doing this and 1 police car passed in the other direction - no one stopped.
anyway I whipped the plug out and that looked ok, but on removing the head things were not well! The carb was properly jetted and still tight and a quick check with a fag paper showed the timing to be ok.
I'll take the timing cover off next and check the oil feed, I'll need to clean out and check the oil pump anyway, although so far there is very little debris in the cases - I may split them to make sure everything is clean, the big end seems undamaged.
Piston
Sorry to see your poor piston. Does the bike run an air filter? Could something have got sucked in?
Best regards, Al.
In reply to by alan_hesslewood
This happened to me whilst travelling at 65 mph with my 88 on the A12, sudden loss of power and white smoke from exhaust.Called out my breakdown service, at home I took the head off to find a hole in the piston. A new experience for me and asking around I was advised that it was most likely to be a faulty spark plug so I changed the pistons and the plugs and that was 10,000 miles ago and still Ok
Ignition and/or fuel problem. From your description of how it failed either it suddenly got a weak mixture or the ignition slipped. Manual advance/retard? cable ok?
Hi Peter
That was my thought, it's a tight wire advance and was fully advanced, checking it on the bench when I got home every thing was working and the timing was right. Carb settings are the same as my other 3 and no obvious problems - carb was tight the flange was a little dished but nothing the o ring couldnt handle!  Ill test the mag when Ive fitted my spare engine and might invest in a new carb (ive never regretted buying a new carb!)
ps I dont understand why the plug doesn't show signs of over heating?
dan
A hole like that is usually caused by pre-ignition.
Common causes of pre-ignition are a too-hot grade of spark plug, buildup of carbon, or the timing and weak mixture issues mentioned above.  Even running low on fuel can do the damage.
Photo is a little blurry here, but is the edge of the piston at the inlet valve cutout eroded?  That would show a history of detonation (pinking).
Is quite accurate; there is evidence of pre ignition. I also feel the collapse of the piston looks like a structural failure rather than a melt (crack lines)  My piston failures (mainly on two strokes) have always been a melt due to mixture issues.
Had there been any work carried out on the piston previously? Motor & plug looks to be in good order otherwise.
Dan, with regard to non stopping bikers, I got a lecture off the boys in blue when I stopped to help a biker with out fuel on the M50. The gist was unsafe, untrained and a distraction to other road users.  I now follow the code of our new generations.
cheers
Hi Dan,
   It looks like this was your first distance run judging by the lack of carbon on the crown. What piston is this as the valve cutaways look offset to each other and I can see the part number cast in the inlet valve one, perhaps a Harley Davidson ?
   Looking at the hole and its surrounding material it appears to have been punched through by the state of the jagged edges, and not burnt through. I think this may have been caused by a combination of pre-ignition and poor quality piston material as the pinking is like constantly hitting the piston with a centre punch, allied with 300 psi of combustion explosive pressure. You say the ignition timing is correct, but what data are you using as high compression and modern fuels need different settings than were used only a few years ago.
   I think you will need a full strip down as you may find a few pieces of the crown in the sump. If you are using the earlier Alfin bi-metal cylinder head, the compression ratio should be a maximum  9 to 1 using premium petrol or 9.5 if you have the 1957 all aluminium type.
Hi Jon,
   Sorry if I have repeated your info as I was having tea and cake while typing so didn't see your post when I started mine !
Hi Richard
Not my first long distance run, I've made the run to Dawlish a few times, plus It had a good run to the new forest at Sammy millers although that was not un eventful as I was knocked off!
Its an ART/Yamaha OEM piston so I'm not too concerned about the material quality. Compression is about 9.5 to 1 - all aluminium head the top of the piston has dipped in the middle, so it got pretty hot!
I run 99 octaine Esso super unleaded, from the pic below you can see erosion on the inlet, which suggests over advanced timing - but the mag behaves normally, if I retard the timing an 1/8th of an inch or so it starts and ticks over slowly, on fully advanced it ran nicely with no noticeable pinking - mind you it's quite loud!
I may never get to the bottom of it, but a quick swill through the sump plug only found small flakes of aluminium but I'll split the cases now its apart and give it a good clean including the oil pump.
Piston2
Cheers Dan
Jonathan,
With regard to stopping I wouldn't stop unless it was safe to do so, I know how dangerous the side of a high speed trunk road is - I used to work for Highways England/Agency, and  I would have waved them on anyway, but when I was in the lay-by working on the bike it would have been safe, - Also bl++dy typical that there wasn't a traffic officer in sight! To busy on police parking areas pretending to be police cars no doubt!
Dan
My  expectations of support  when in  trouble  have  slowly eroded over the years.  I had a  puncture over at  Stamford  some  years ago,  Biker stopped and dropped a can of Tyre repair gunk for me. He had spotted me earlier, travelled on to Stamford, picked up the "gunk" and  returned; wouldnt take payment.  I was up and away and only half hour late at me Cambridge  destination. Looks a conundrum to solve.
There has been some nipping on the bosses so the piston was well up in temp.  The dip usually translates to melt with smooth edges to the crater.  Richards description regarding the centre punch is quite right.  Maybe the modern material of a Yamaha fails in this way? I take it the spark  plug is at the failure position.
The previous reply regarding too hot a plug is beyond my knowledge.  I assume the heat is generated by the mixture of fuel, by not the rating of the plug. But that's something for me to  learn.
Best  regards
Can a bike like that ever reliably run a 9.5:1 ratio with road fuel?
Detonation at road speeds, that you can't hear is (perhaps obviously!) the worst kind.
A too soft (hot) plug will run at a higher temperature than the motor needs and will pre-ignite mixture and do damage. The plug is not showing that but has been well contaminated with burnt oil from the hole so its not readable.
Running at 60MPH you must be in the realms of main jet influence. Maybe too small or as  suggested  by my good friend Martin, build up or partial obstruction on the jet from deposits due to modern fuel characteristics. May be worth dropping the bowl and taking a look.  Then I guess fuel flow restriction could be further investigated back to fuel line, tap and tank breather.....
J
Jonathan
I have 3 of these engines, two are seriously abused!  all fitted with 1 1/8 389  monoblocks jetted to suit the Mk2 Es2, this one has a 290 main jet, I've reduced the other 2 to 280 as they were running a bit rich - I've pulled the carb apart and everything looks good - it had new jets, needle and slide before it was fitted. I'm still leaning towards the mag, or my timing, I know I timed it with a cigarette paper but cant remember if I checked it with a strobe!
I should add that the engine runs fine on 99 octaine super unleaded - or rather it did!
dan
Are a source of great envy! I run a 280 Main jet on my single. It's a touch rich but helps with starting as she needs plenty of fuel to get going.
Be worth confirming your static settings before you pull the motor down.
To be continued no doubt...
Dan, You didn't tell us what sparkplug you are using.
The size of main jet only matters if you have the throttle FULLY open for several seconds (5-15 seconds). I doubt that many road ridden machines ever experience that.
If you look at Amal carburation graphs for the effect of all the jet sizes, over the whole throttle range, the main jet effect is only there at wide openings. The pilot jet and airscrew has an effect up to 3/4 throttle opening, the needle and needle jet are the main players in poor carburation.
Just my opinion but any other views are equivalent.
Spark plugs is a B7ES, I 1/8th monoblock Carb, 25 Pilot, 3.5 Slide, 290 main, 106 needle on clip 3 - ie standard MK 2 ES2 - It prob was in main jet territory as I was running up the hill. Fuel 99 octaine - no air filter - tight wire mag.  I did a quick check of the timing before I took the engine out, but sadly after I had taken the head and barrel off, it was in the right ballpark - about 40 degrees BTDC.
New piston and small end bush are on their way, in the meantime I'm putting a standard ES2 engine in the frame using the same mag and carb - so a chance to do plenty of testing!
Dan
The technical information on Green Sparkplug site says that a hotter running plug ends up damaging itself but not the engine. I holed a piston on my twin a few years ago after only about a mile doing about 70.  I put it down to running lean on one side, because my siamesed pipes were not equally clear flowing inside.  I never heard any pinking.  I still suspect a defective piston.
Does high speed pre ignition happen without any warning sound of pre ignition on hard acceleration beforehand?
"The technical information on Green Sparkplug site says that a hotter running plug ends up damaging itself but not the engine."
Then that technical information is wrong.
Detonation and pre ignition are actually different things!
Detonation or knocking is the audible one, usually,  but not only caused by over advanced ignition. Lean mixture, excessive top land clearance on the piston, wrong squish area can also be causes. Combustion is still controlled,  but cylinder pressure peaks will be very high, which can cause damage if it is continually occurring.
Pre-ignition is where combustion occurs uncontrollably, usually triggered by something too hot in the combustion chamber (plug electrodes and exhaust valves are usually favourites). In effect the engine is acting like a diesel. It is usually inaudible. If you are very sensitive you might be lucky and feel the loss of power and be able to close the throttle before damage occurs, but most cases lead to failure.
Detonation can lead to pre ignition,  but it isn't the only cause.
Hope you get to the bottom of the cause.
Regards, George
(Too many years spent in engine development!)
Detonation and pre-ignition are different things, but that piston looks like it's seen quite enough of both.
Hi Dan,
   Just thought I would offer another possibility on your piston failure. If your piston is from a water-cooled engine it may not be made to the same specification as an air-cooled one. The general temperature of a water-cooled engine will be controlled at probably 95 degrees centigrade, whereas your big bore Model 50 will run at a much higher and un-regulated temperature. Older racing pistons, Specialoid in particular, had support webs under the the crown to give extra resistance to the increased heat and pressure and were possibly made of a higher spec alloy.
   The ignition timing sounds too advanced at 40 degrees BTC, 36 might be better on 9.5 to 1 compression and general road use. I think your piston had started to collapse over some time and the incline was the last straw ?
I am with Richard on this one. Thought the piston crown looked too thin for an air cool motor.Also todays fuel reputidly burns faster and needs less advance.
The piston is OEM Yamaha XT500, aircooled and a good quality, the same pistons are in my race bikes which get a much harder life I can assure you, especially when chasing down 650 triumphs, my favourite sport!
Richard, when i set it up i timed it at 38 btdc, my check was rudimentary as the barrel and piston were off, i was just checking the ball park.
but i think i may have a mag problem watch this space!
dan
