HAVED RECENTLY PURCHASED 69 COMANDO ROADSTER NOT SURE WHAT FUEL TO RUN IT ON BEEN STORED LONG TIME...
Not knowing if the engine…
Not knowing if the engine is a Combat type or not, I would recommend starting with the highest grade available and work your way down from there. At the next fill up try the next lower grade. If the engine does not ping or knock, go to one lower grade, etc.,etc...
