I got a frame and forks in a job-lot. the only number I can find on the frame, at the headstock, on the downtube part r/h side is 9955. It has forks which look like jubilee but the frame has a single top bar and is open at the bottom and has a sprung swing arm. Of no help it is painted red-lead red. (just thought i'd throw that in) so wot's it from?
Hi Robert, dont think its…
Are you sure the frame is…
Are you sure the frame is Norton? The Jubilee forks were an AMC product and were used on a number of AMC bikes, such as Fanny Barnett and James as well as the Norton. I'm not sure if they were also used on the Ajay 250cc Model 14 and its Matchbox badged brother.
can you write me at < l…
can you write me at <lighttwins@nortonownersclub.org> I can take you through it in detail. Have not time to read all the threads at present - unsure where you have got to
Hi Robert, dont think its a Jubilee as they have a double top bar also the frame number is usually near the swinging arm pivot.
