Is it possible to swap out the cigar silencer exhaust system on a 1969 Commando Fastback with the peashooter system?
Many thanks, Peter.
Many thanks, Peter.
I did exactly that on my ‘69…
I did exactly that on my ‘69 Fastback back in the day - first fitted Dunstall “decibel” silencers in place of the the original cigar type , making a bit of a bodge-up mounting on the original brackets , then fitted peashooters using correct brackets that were easy to source back then. You’ll probably need to hunt around a bit for the correct peashooter brackets these days.
No hunting required
The bracketry is available from the usual suppliers, stainless as well!
My fastback
Has the upswept silencers, in my mind it looks better.
Gino
Many thanks for your advice,…
Many thanks for your advice, Gents, and yes, Gino, the peashooters do look a lot better.
You will need the pipes and brackets to suit as well.
