Does any one know a way of removing ignition stator/cam it says in book remove retaining bolt and insert another bolt to remove cam etc or any one know the length and thread or any were that sells such a tool.Keith
Keith, In many cases a gen…
Keith,
In many cases a gentle sidewaystap with a piece of wood will separate the taper.
The dimensions you ask for are:-
Take a 5/16 x 26tpi (CEI) machine screw with 2.05 ins thread. The screw must be threaded full length.
Turn down the end for 1.3 inches to 0.270/0.268 ins diameter.
This leaves 0.75 ins of thread under the screw head.
You have your extractor.
You can play around with studding and longerscrews to make something similar, but the key dimensions are 5/16 CEI, 0.270/0.268 insand 1.3 ins.
Good luck
Peter Holland
Previously keith_hammerton wrote:
