Enfield hub bearing adjustment
On my 31 model 20, I followed the hand book advice on bearing adjustment.
I set the bearing with very slight play. Then tightened the left axle nut ( right is already tight ) and all my play is gone!. I loosen off axle nut and make small adjustment then tighten the nut. Once again all my play is gone..20 minutes later I finally got it but I had to put a fair amount of play in first before tightening the axle nut..Seems to me every time the rear wheel comes out one needs to adjust the bearings which doesn't seem right or am I missing something here?? .
