Does anyone know the number of teeth on the fibre and drive pinions on a 6V Lucas DC generator Type E3H on a Model 7 (and 77) ? regards, howard
Pinion size
Dynamo drive gear
Following some research I think it should be 23 teeth on the dynamo shaft. I think Norvil stock this.
I've been looking for one at autojumbles for a while now, without success.
I'll be interested in the fibre gear and where to obtain one.
Fibre gear
Hi
the fibre gear is the same as used on the single MO1 Lucas magdynos. It is the spring/clamp assembly that is each side of the gear that is different.
On a Dominator I bought, the dynamo pinion teeth did not fit properly into the fibre wheel - didn't mesh right in. Norvil supplied me with the correct one, only fractionally bigger diameter.
I hope this helps.
