My bike has a single 376 Monobloc with small plastic bellmouth fitted and no filter. It has the air filter box between battery and oil Tank. I see the club does a D shaped one. Are there any other bits i need other than some sort of rubber to the carb to run it with a filter?
thanks
The big box filter that…
Vokes Type
Here's mine, just needed a rubber connector and two jubilee clips. Oh and an Austin mini air filter cut in half.
Did you have cut airbox?…
Did you have cut airbox? Does battery box still fit Ok? Thanks
Didn't have to cut anything…
Didn't have to cut anything and the battery box fits perfect - you'd never know there was an air filter in there.
Looks a lot easier to fit…
Looks a lot easier to fit than the big Norville box.
More info please
Are there any drawings or pics of the original filter arrangement please
The big box filter that Norville sells needs a carb screw on ring and a rubber connector to link up with the spigot on the box.
