Could someone tell me the size of thread on the drive side end of the crankshaft please? Specifically on an alternator model.
Thanks in advance,
John
5/8" x 20 TPI , and most…
The drive-side alternator…
The drive-side alternator crankpins are one-peice and beyond the main bearing shoulder have a reducing taper shoulder with a woodruff key( to take the engine sprocket), then a parallel section with a woodruff key (to take the alternator rotor) and then a 5/8 inch BS Cycle 20 tpi threaded section for the nut. There are no screwed-in studs unless a Dynamo type crankpin has been modified as such. Cheers, Howard
5/8" x 20 TPI , and most likely cycle . ( I don't really know all this stuff, just know where to look).
