Crank case oil leak
Hi , has anybody had to replace a seal believed to be between the alternator and the back of the crank case .
the gasket on the crank case does not seem to be leaking .
regards Martin
No , other side , I since been told that there is a cable that goes through the back of the caseing but not sure if it is how to seal it .
Regards martin
Part 30?
https://andover-norton.co.uk/en/shop-drawing/65/chaincases-chains-sprockets-clutch-alternator
Old ones become hard and the hole opens out, fit new soft one plus a bit of silicone goo for backup.
