Camshaft drive pinions
Are they the same as the Dominator or other models?
It's really hard to know what you are asking. The camshaft drive on the light twins is done by gears, whereas the dominator and commando are by means of a chain. The singles do have gear driven cam shafts. The best way to see if the same part is used on different engines would be to look in the parts books and compare part numbers.
