Air slide sticks when I tighten the top cap!
I've heard of slides sticking because the flange nuts are done up too tight - but has anyone had a slide stick when the top capheads are tightened?? As long as I keep the capheads just finger tight (looser the better) it works fine. I'm using a single amal carb supplied by Andover.
Hi John I know this might sound a bit soft but is the cap being fitted the correct way around,
Paul.
Tightening up the screws could be distorting the carb. I think this is quite common. Some metal polish should clean it out enough to get it working no trouble. But don't over do it, you dont want an air leak.
The website encountered an unexpected error. Please try again later.
