hi a bit of help pls im having some issues with the idle on the above bike .it starts from cold ok and i can set the idle using the prescribed method ,however after another start when hot the idle does not alway return to prev settings ,sometimes will idle for a while (enough time to get your helmet on )then it will stop ive replaced the "o" rings on the adjustment screws for more friction should the screws be moving ,everything else seems ok timing etc bike has 17k on it, was suggested replace carbs with new prem types ??if i go this route (expensive) would it be better to fit the later 32mm options ??? a note im recovering from cancer treatment so i need bike to start reliably when hot as i have last some (a lot) of weight (strength) and would like to enjoy the bike more any help much appreciated rgds steve
You tune the idle at…
A touch richer
John's advice is good, but I've discovered that after tuning the idle as per the normal method I find that if you then set the mixture screws a touch richer than need be you get a more stable idle with a hot or cold motor.
I usually adjust the mixture screws in a further 1/8 to a 1/4 turns from the normal optimal setting and then re-adjust the idle screws to suit .
500 to 600 rpm idle is then possible.
Short video of warm up idle:-
https://photos.app.goo.gl/Fj3qxetqkvBhuDH69
Good luck!
Ultra-slow idle speeds may…
Ultra-slow idle speeds may confer fun bragging rights, but I'm not convinced that they're a good idea. In his new book Norman White suggests 800 rpm.
On a different note, if Stephen finds any traces of dirt, encrusted deposits, etc, in his carbs a trip through an ultrasonic cleaning bath is recommended — did wonders for my Amals.
(To the best of my knowledge these latter are veterans from 1972; when I first got the bike it ran absolutely terribly on moderate throttle openings, cured with new needles, needle jets and anodised slides. A subsequent problem with starting and warm-up was cured by the ultrasonic treatment.)
thx guys
just to explain the bike came from a collection so had not been used much (in retrospect should have bought off noc) however didnt join till ownership that being said carbs electronically cleaned white nylon floats, new filters and tank cleaned boyer ignition anyway thanks every body for rapid responce as i have had cancer treatment to throat i cant put helmet on then start bike as i make no saliver so cant cick away, but would like to use the bike in nice country roads around dorset anyway ill try all thxs regards steve
You tune the idle at operating temperature for best running. You should retune for best idle when fully warm.
This means by default it is not tuned well for idle when cold and so needs some revs to keep it running until some warmth is in the engine, it's not a modern ECU controlled fuel injected engine.
So you need to keep it rich when cold by either tickling a bit more, doing a second tickle after it starts, and/or adding back in the carb chokes if they have been removed and using them.
You likely also have worn slides, so as long as the carb bodies have also not worn as badly you can fit new anodized slides and reduce both air leaks and the rate of future wear.
I put my helmet and gloves on first and then I can use the throttle to keep the bike running until I get onto the tarmac 400m later and then it will be warm enough for a reliable idle.
I also have a Digital red box Boyer, this has an idle stabilisation advance curve, as the revs drop below 900 the ignition advances and the revs rise back up.
32mm carbs are only needed for Combats and 850's, not std 750's.
