I'm hoping someone can shed some light on this issue, which is perplexing me!
I have a couple of JPS Nortons in the shed. Problem is they both have different fairings and different exhaust mounts.
Is one a replica or did the Norton factory produce two types of fairing? I have collected a decent quantity of period photos and magazines which feature the JPS, but I can't see a consensus there either!
Photos of the two are available in the link below:
Both have frame numbers that indicate a Commando MkIIa. I can provide those numbers if needs be.
Regards,
Jerome
Your JPS2 has the correct…
Your JPS2 has the correct mounts for the annular discharge silencer fitted to the JPS. They were all Mk11As, weren't they ? JPS1 has most of the mounts for the earlier reverse cone silencer.
Do both bikes have the extended fuel tank under the shroud ? Many replicas have simply the Roadster tank.
In addition to original fairings, there have been post-production versions from Sprint (using the original moulds I believe) and Curley (Specialist Mouldings ?). The Curley versions never looked quite right to my eyes.
